ᐅ How can I increase the load capacity of Ikea BESTA shelves?
Created on: 14 Jan 2020 09:06
dumar
dumar
14 Jan 2020 09:06
Hello everyone, I am currently looking into ways to increase the load capacity of my Ikea Besta shelves, as I would like to use them for heavier items without the shelves bending or the structure becoming unstable. My question to the community is: What options are available to significantly improve the load-bearing capacity of these shelves? I am interested in technical modifications such as reinforcements and materials, as well as assembly techniques or alternative installation methods. It would also be helpful to know the realistic maximum loads that can be handled without compromising the warranty or stability.
Jonas66
14 Jan 2020 09:22
To increase the load capacity of your BESTA shelves, you can install additional shelves made from stronger material or reinforce the load-bearing surfaces with metal brackets. It also helps to mount the shelves directly to the wall and on a solid floor.
Tevin
14 Jan 2020 10:04
Hello dumar, your question is very practical and important for everyone looking for more stability in the BESTA shelves. First, I would point out that the shelves are standardly built with plastic or particleboard shelves designed for moderate loads. To improve load capacity, it is recommended to:
- Use thicker or more solid shelving boards (e.g., plywood or MDF with greater thickness)
- Install additional center supports or metal profiles under the shelves
- Reinforce the back panel for better resistance against lateral bending
- Ensure a fixed, secure wall mounting using high-quality anchors
Together, these measures can easily double or even further increase the load-bearing capacity, depending on the implementation. However, be careful to perform the drilling and fastening cleanly to avoid weakening the carcass material.
theota
14 Jan 2020 11:47
Interesting question! I always find it a bit odd how IKEA furniture is often praised as being all-purpose. The BESTA series is not designed for heavy loads but rather as a design product for lighter uses. If you really want to support heavier weight, to me that usually means investing in a completely different shelving system. Of course, you can do some modifications—like adding metal brackets or extra wooden strips for reinforcement. But in the end, it’s a compromise between what the furniture material allows and how much effort you want to put in. Sometimes, achieving greater stability with less effort just isn’t possible.
Samuel
14 Jan 2020 12:35
Hey dumar! 😄 With a few clever tricks, you can turn your BESTA shelves into real powerhouses! 💪 The key is not just to place the shelves in, but to support them properly. For example, you can install metal braces or wooden boards crosswise under the shelves for extra support. Don’t forget the back panel either – it adds a lot of stability when securely attached. And if it’s going to carry really heavy loads, consider using steel brackets as well. A bit of DIY spirit really makes a difference. Good luck!
V
vincent46
14 Jan 2020 14:18
I understand that you want to make the shelves more durable without constantly worrying about anything giving way. I once tried storing heavy folders and boxes in BESTA shelves myself – and after just a few months, the shelves started to sag slightly. A really good solution for me was to screw wooden strips to the underside of the shelves, which adds stability almost like a frame. Additionally, I secured the shelves to the wall with wall hooks to prevent them from tipping over. It simply feels safer afterwards.
