Hello everyone, I am planning to convert my Ikea Besta media cabinets into an open shelving unit and wanted to ask for advice on the best approach. Specifically, I want to completely remove the back panels to create an open look and possibly add extra shelves without compromising stability. Has anyone had experience converting a Besta unit into an open shelving system? What materials work best, and how can I make the whole thing safe and visually appealing? I would appreciate any tips and tricks you can share!
When remodeling the Ikea BESTA, removing the back panels is generally not a problem, but the structure can become unstable. I recommend adding extra vertical supports or reinforcing the sides with brackets. For the shelves, use extra-thick particle boards (at least 18 mm (0.7 inches)) to prevent sagging. Make sure all connections remain screwed and, if necessary, additionally secured with wood glue.
So, if you want to convert the BESTA into an open shelving unit, that’s a pretty cool idea! 😎 I saw it once at a friend’s place: He removed the back panel, installed stylish metal braces, and added some LED strips – a clever way to hide the screws😉. Stability? Of course, it becomes more important with an open shelf, so it’s better to add extra reinforcement. Good luck!
The BESTA frame is modularly designed, so back panels can be removed without compromising the entire system, as long as certain points are considered. First: the back panel acts as diagonal bracing and absorbs longitudinal forces. Without it, another form of bracing is definitely needed—preferably metal corner brackets or cross braces made of wood or aluminum. Second: additional shelves should ideally be reinforced with support profiles, since the factory-installed thinner boards tend to sag too much, especially under heavy loads. Third: wooden braces can be installed discreetly inside, which helps improve stability without significantly affecting the open design. Do you plan to have the shelving unit freestanding or fixed to the wall? Wall mounting is generally recommended, especially for open constructions.
kaubi schrieb:
The BESTA frame is modular in design, so the back panels can be removed without compromising the entire system, provided certain points are observed.Thank you for the detailed information. I will mainly secure the shelving unit to the wall. Do you have any recommendations on how to best carry out the mounting so that it remains invisible and stable? Also, what spacing would you suggest for the shelves if I want to accommodate both books and decorative items?
