ᐅ How can I convert Ikea BESTA into an open shelving unit?
Created on: 15 Apr 2024 09:12
Jake67
Hello everyone, I am planning to convert my Ikea Besta media cabinets into an open shelving unit and wanted to ask for advice on the best approach. Specifically, I want to completely remove the back panels to create an open look and possibly add extra shelves without compromising stability. Has anyone had experience converting a Besta unit into an open shelving system? What materials work best, and how can I make the whole thing safe and visually appealing? I would appreciate any tips and tricks you can share!
Dustin
15 Apr 2024 14:02
Material handling alone is sufficient for 18 mm (0.7 inch) panels, but for secure fastening, especially under load, I recommend additional screwing to the side frame profiles.
meGreg
15 Apr 2024 14:30
I would also suggest: If you’re already at it, build small recesses for LEDs. An open shelf like that feels much cozier and looks great. And don’t worry – it will be stable if you follow the tips here.
Jake67
16 Apr 2024 08:45
Dustin schrieb:
For a secure hold, especially under live loads, I recommend additional screwing of the side frame profiles.
Thanks, I will do that. One quick question: What is the best way to treat the surface of the plywood panels to prevent them from scratching or staining too easily? Oiling, painting, or maybe hard wax?
tra_nina
16 Apr 2024 09:10
Plywood is best treated with an oiled or waxed wood finish to preserve the natural appearance while still providing protection against moisture and wear. Painting offers more protection against stains but often looks less natural and can be harder to repair in case of minor damage. Hard wax is a good compromise and can be easily refreshed.
kaubi
16 Apr 2024 09:38
Jake67 schrieb:
A quick follow-up question: What is the best way to treat the surface of plywood panels to prevent them from scratching or staining too quickly?
Oiling provides a natural finish with a water-repellent effect. Make sure to apply several thin coats of oil and allow each layer to dry thoroughly in between. Alternatively, I recommend a hard wax oil, which creates a durable, matte surface. While varnish is more resistant to scratches, it can be problematic on plywood because the layers and edges are often prone to cracking.
Jake67
16 Apr 2024 10:01
Perfect, thanks to you all! The information here is very helpful for finalizing the planning. So, I will:
- Remove the back panels
- Add sturdy brackets and cross braces for reinforcement
- Use 18mm (3/4 inch) birch plywood
- Replace the metal shelf supports
- Screw the shelves from the sides
- Treat the surface with hardwax oil
- Additionally secure it to the wall
I’ll get in touch when I start or if I have any questions during the renovation. Thanks to everyone for the helpful tips!
