ᐅ How can I modify IKEA BESTA units to create a room divider with open sections?
Created on: 8 May 2020 08:34
sodosoHello everyone, I am considering how to redesign my IKEA Besta system to function effectively as a room divider. Specifically, I want to incorporate as many open elements as possible to create an airy separation between two living areas without making the space feel completely closed off. I already have some plans, but I’m still looking for a solid approach to integrate the open elements without compromising stability and functionality. Does anyone have experience or tips on converting BESTA units into a room divider with open compartments? I’m especially interested in suggestions for connecting the units, possible modifications to the back panels, and the best combination of doors, drawers, and open cases.
To convert BESTA into a room divider with open elements, I recommend the following approach: - Omit continuous back panels to allow visibility through the unit or replace them with glass back panels. - Connect the modules using sturdy brackets or specialized connector kits, which IKEA sometimes offers separately. - Use open cabinets (without doors), possibly supplemented by individual units with doors or drawers for storage and structure. - Use decorative items or plants to emphasize the open compartments. It is especially important to ensure stability at the module connections since the room divider often functions as a double-sided piece of furniture.
What I am wondering: How exactly do you define "open elements"? Are these completely open compartments without any closure, or are you referring to partially open doors, glass panels, or inserts made of grilles? Depending on this, the structural classification and possible load capacity will change. This would be crucial for the planning.
Thanks for your input so far. To clarify: by open elements, I mainly mean carcasses without doors or drawers, where you can see inside from both sides. I plan to either leave out the back panels entirely or replace them with transparent versions to keep the space as light and open as possible. The connection should be stable so that the room divider doesn’t wobble or tip over when touched. Basically, I want to stay modular to be able to rearrange it later if needed.
That sounds like a great project! With open room dividers using BESTA, I’ve had good experiences connecting the individual modules with long metal brackets on the sides and securing them to the ceiling with tension cables for stabilization. Completely without back panels. This creates enough openness while ensuring the structure is stable. Additionally, decorative elements can be placed inside to add visual structure.
