Hello everyone, I am currently looking into ways to increase the load capacity of my Ikea Besta shelves, as I would like to use them for heavier items without the shelves bending or the structure becoming unstable. My question to the community is: What options are available to significantly improve the load-bearing capacity of these shelves? I am interested in technical modifications such as reinforcements and materials, as well as assembly techniques or alternative installation methods. It would also be helpful to know the realistic maximum loads that can be handled without compromising the warranty or stability.
It’s great to see this topic being discussed here! I really like it when furniture isn’t just used as is, but gets a bit of an upgrade through small modifications. Especially with the Besta shelves, I’ve found that adding extra reinforcement at the back with a plywood panel can work wonders. I attach it using screws and some wood glue to ensure it holds firmly. And yes, I would also support the shelves themselves with metal brackets – it can’t hurt, and if done neatly, it even looks stylish.
Thanks for the advice so far! I have a specific question: Should the focus be more on reinforcing the floors themselves, or is the stability of the side and rear walls more important to increase the maximum load capacity? I imagine the walls hold the entire structure together, but if the floors sag, that doesn’t help much either. What order of measures makes the most sense here?
dumar schrieb:
Is it better to focus on reinforcing the floors themselves or is the stability of the side and back walls more important?Good question! I would say that without stable side and back walls, even the best floor reinforcement won’t provide much long-term benefit. The walls are the frame that supports the weight. So first, secure the walls, for example with strong screw connections and possibly additional corner brackets. After that, address the floors, which should be reinforced using metal profiles or battens to make them rigid. This way, the components work together properly, significantly increasing the overall load capacity.
A very interesting topic! I have often experienced within my circle of friends how frustrating it can be when shelves do not live up to expectations. That’s why I find this discussion so valuable, as specific questions are asked and answered here. I’ve noticed that many try to achieve maximum stability with minimal means – but this rarely works in the long run. It can also be helpful to consider which loads occur regularly and whether using several shelves instead of one heavy-duty shelving system might be better. Sometimes redesigning the setup to redistribute the load differently helps as well. Thanks to everyone for the many tips, which show that there usually isn’t just one solution, but rather a combination of materials, construction, and use.
