ᐅ How can I build an IKEA BESTA unit as a shoe cabinet with proper ventilation?
Created on: 3 Dec 2023 10:12
gupapar
gupapar
3 Dec 2023 10:12
Hello everyone, I am planning to build a shoe cabinet using the IKEA Besta system because I really appreciate the storage space and design. However, I have concerns about ventilation, especially since shoes often release moisture, and I want to prevent unpleasant odors or mold from developing. My question is: How can I modify or design the IKEA Besta shoe cabinet to ensure sufficient and effective ventilation? Are there proven methods to adjust the cabinet, for example by adding ventilation slots, special inserts, or arranging the shelves in a certain way? What materials or additional components would you recommend to allow as much air circulation as possible without affecting the overall appearance? I look forward to tips, practical experiences, and also warnings about potential pitfalls in a project like this.
Greglau
3 Dec 2023 10:46
The easiest solution is ventilation holes or slots on the sides or back walls. For example, you can install thin metal grilles that allow air to pass through but keep out dust. Additionally, it helps not to make the floors completely airtight; for instance, try using perforated floors instead of solid floors.
KLO-KA
3 Dec 2023 11:15
I would definitely recommend leaving some kind of air gap at the back of the cabinet. You could use spacers to maintain a gap from the wall or install a perforated back panel. This way, air can circulate more effectively.
geralu
3 Dec 2023 11:43
Ventilation slots milled past the bottom and top of the door allow air to flow in at the bottom and out at the top. This creates a natural airflow. Just make sure the stability of the cabinet is maintained.
gupapar
3 Dec 2023 12:22
Thanks in advance for the initial advice! I would like to ask more specifically: Would it be sufficient to replace the back panel with a thin metal mesh, or would it be better to also create side openings? I’m concerned that having only the back panel might not provide enough ventilation, especially if the cabinet is placed directly against the wall.
CHENFAR
3 Dec 2023 13:07
Solely ventilating through the back panel may be insufficient depending on the cabinet’s position, especially if it is placed tightly against the wall. Ideally, both the back panel and the side panels should be ventilated in a controlled manner. - Replace the back panel with a metal or plastic grille. - Mill ventilation slots at the top and bottom of the side panels. - Do not seal the bottom completely; consider using spacers to create a gap above the floor. Additionally, it is advisable not to place the cabinet directly against the wall but to leave a small gap of about 2 cm (1 inch). Keep in mind that air circulation is only effective when air can flow in and out.
