ᐅ How do I remove scratches from the surfaces of Ikea BESTA units?
Created on: 24 Mar 2023 14:07
GO-COLLIN
Hello everyone, I have a problem with my Ikea Besta furniture and need your expert advice. There are scratches on the surface that are not deep but visible and affect the uniform appearance. The BESTA surface is melamine-coated, which probably makes repair more difficult. My specific question is: which methods and materials can be used effectively to remove or at least significantly reduce the appearance of such scratches without damaging the melamine coating? Are there any products, home remedies, or special techniques that have proven effective in practice? Thank you very much for your detailed tips!
narDietmar
24 Mar 2023 18:43
As an addition: Ikea Besta melamine panels are very durable; however, I would generally avoid using products that contain solvents, as they can damage the surface.
A professional alternative is treatment with special repair waxes or furniture lacquers that are certified for melamine surfaces. It is also important to apply a protective layer after the repair, such as a plastic care product, to protect the treated areas from moisture.
GO-COLLIN
25 Mar 2023 09:14
pikin schrieb:
It is important not to use sandpaper, as this could damage the melamine coating.
Thank you for the clarification. From this, I understand that mechanical sanding is not a good idea. How much polishing is acceptable before the coating is actually at risk? Do you or anyone else have specific product recommendations for polishers designed specifically for melamine?
pikin
25 Mar 2023 09:55
GO-COLLIN schrieb:
How much polishing is allowed before you actually risk damaging the coating?
You should only polish very lightly, using gentle pressure and short movements, to avoid thinning or dulling the surface. It is more of a gentle surface treatment than actual sanding.
Regarding products: I recommend plastic care products with a polishing effect, such as "Pledge Multi Surface Polish," or specific furniture polishes designed for plastic or melamine surfaces (please check the ingredients beforehand). Wax sticks are available in various colors, for example, "furniture wax fillers" from brands like "Holts." These can be found at hardware stores or specialized retailers.
Tinaneo
25 Mar 2023 11:36
I would like to point out that the effectiveness of polish and wax sticks is quite limited. If you have really deep scratches on melamine, you should avoid experimenting with home remedies and instead consider suitable replacement parts or even replacing the panels or fronts.
By the way, I wonder: How unique are these scratches in practice? Is the effort really worth it, considering that melamine is a very hard surface but not repairable like wood or paint?
TEOZAR
25 Mar 2023 14:28
Tinaneo schrieb:
Is the effort really worth it, considering that melamine has a very hard surface that, unlike wood or paint, cannot be repaired?
This concern is valid. In many everyday situations, minor cosmetic repairs are sufficient to keep the furniture looking good. A full restoration to the original condition is indeed rarely achievable.
Those who still prioritize optimal repair should, if possible, consider original replacement parts, especially for more significant damage.
Gloriagl10
26 Mar 2023 08:47
Quick tip: Try using a polish designed for automotive plastic parts to remove scratches. These polishes are durable and often effective on melamine surfaces. Simply apply and gently rub it in.
