ᐅ How can I convert Ikea BESTA into a storage bench for a children's room?
Created on: 7 Mar 2024 09:24
kefe52
I would like to build a storage bench in my son’s bedroom, and I have chosen the Ikea Besta system for this purpose. My goal is to modify the BESTA cabinet units to create a sturdy bench with enough space to store toys.
My specific question is: How can I convert Ikea BESTA into a storage bench for a child’s room that is both strong enough to support children and provides easily accessible storage? Are there particular modules or add-ons that work especially well? Tips on reinforcing or adjusting the doors/panels would also be very helpful.
I look forward to your experiences and suggestions!
Joshbe schrieb:
3. Storage: Pull-out boxes or insert baskets increase usability.I think drawers or boxes are basically a compromise between order and chaos. If children are really supposed to learn to put away their toys independently, then open shelves or baskets tend to work better – accessible, clear, and quicker to put things in and take out.
Of course, the bench seat won’t look tidy, but maybe that’s an important part of development that should be encouraged.
So here’s my provocative question: Is storage with handles and doors really the best solution for a child’s room, or is it more of an aesthetic ideal that satisfies adults?
Hey everyone!
Great topic! I really like the idea of using Besta as a bench with storage, especially because it’s so versatile. 😊
For the upholstery, I would go with kid-friendly designs – that makes it much more inviting! And don’t forget: use felt pads under the bench, especially if it’s on laminate or hardwood flooring, to protect the floor and make moving it easier.
Also, consider using small storage boxes in different colors; this helps children keep things organized using a color-coding system! Good luck with your project!
GALEO4 schrieb:
Is storage with handles and doors really the best solution for a child’s room, or is it more of an aesthetic ideal that satisfies us adults?Interesting question. I think it strongly depends on the age and maturity of the children. For toddlers, open shelves are definitely practical. But from around five to six years old, a certain level of order with closed compartments and drawers can actually be beneficial.
Another point regarding stability:
For the bench seat, I would recommend using plywood or multiplex boards for the seating surface, as these are less prone to warping over time compared to OSB boards.
And a flexible design, where for example the cushion cover can be removed if needed, is in my opinion ideal.
Here is a summary of the key technical points relevant for a stable and practical conversion of BESTA into a seating bench for a child's room:
- Ensure load-bearing capacity with additional cross braces or metal brackets
- Reinforce the back panel with a 6 mm (1/4 inch) MDF board to prevent warping
- Seat panel made of multiplex plywood or plywood, at least 18 mm (3/4 inch) thick, secured to the frame
- Cushioning with removable covers, preferably attached with Velcro strips or elastic bands
- For storage options: sliding doors or open baskets depending on the child and usage
- Angle braces securing the entire construction to the wall to prevent tipping
The conversion requires some basic carpentry skills but is quite feasible with the measures described.
Thank you very much for all the helpful contributions and opinions!
I will probably build a BESTA carcass measuring 120x40 cm (47x16 inches) with reinforcement of the back panel using a 6 mm (1/4 inch) MDF board and attach a sturdy plywood seat panel with foam padding. The idea of sliding doors is very interesting to me since the playroom is relatively small and I want to avoid an open door getting in the way.
Regarding the seat height, I am aiming for about 45 cm (18 inches), as gregto described, so it will be ergonomic for my child.
Concerning storage space, I am taking your feedback regarding open compartments versus closed storage into account – maybe it will be a combination.
I will report back once it’s finished to share how it turned out. Thanks again to everyone!
