I am planning to build a small desk using IKEA Besta units. The idea is to use the typical Besta cabinets as a base and mount a tabletop on top to create a compact but sturdy workspace. It is important to me that the desk is not too high and remains as space-saving as possible since I have limited room available.
My questions for the community:
- Which Besta dimensions (height, width, depth) are best suited for a small desk?
- What are practical (and stable) methods to connect the Besta frame to the tabletop?
- Are there any tips for choosing and securing the tabletop that will hold up well over time?
I look forward to your experience and advice, especially if you have done something similar before.
LOGEMIN schrieb:
- Adjust the height: Ideally around 72-75 cm (28-29.5 inches) working height, while Besta units are usually 64 cm (25 inches) high. Either use table legs (e.g., from IKEA) or raise the Besta units with a countertopThanks for the detailed advice, LOGEMIN, tips like these are really helpful. I was already wondering how to best adjust the height without making the structure unstable.
Back to the countertop: I want a light wood look, preferably scratch-resistant. Does anyone have experience with factory-oiled or lacquered MDF panels? Are they suitable for desks, or is it better to go for something more solid like real wood? And are there any differences to consider regarding the mounting?
Also: How do you handle cable management or routing with a small Besta desk like this? I want to avoid cable clutter and make the most of the limited space.
warrenka5720 Apr 2024 08:33I know the feeling when you have limited space but still want to create a practical workspace. A Besta desk can really help if you plan it thoughtfully.
For cable management, I recommend:
- Cable clips or small velcro straps underneath the desk
- A cable duct or a small box at the back of the cabinet
I used a light MDF board myself and sealed it with clear lacquer; it works well and protects against scratches.
In general, I think it’s important not to put too much pressure on yourself – especially with a DIY Besta desk, it’s about staying flexible and finding what really works.
Birepa schrieb:
Does anyone have experience with factory-oiled or factory-painted MDF boards? Are they suitable for desks, or is something more solid like real wood better?Factory-painted MDF boards are generally suitable for desks. They provide a smooth, low-maintenance surface that is resistant to stains. However, the surface hardness depends on the type of paint used. Factory-oiled boards tend to absorb liquids more easily and require regular maintenance.
If you want a desktop with high durability, plywood or solid wood boards are better options, though more expensive. Be careful during assembly to avoid damaging the finish – pre-drill holes and avoid using screws that are too long.
Summary:
- Painted MDF: easy to maintain, affordable
- Oiled boards: natural appearance, require upkeep
- Solid wood/plywood: durable, premium quality, costly
Regarding stability: If you use two Besta cabinets, it is recommended to connect them with metal brackets or a cross brace to prevent lateral wobbling.
For the tabletop, plan for a minimum thickness of 2 cm (0.8 inches) to avoid sagging. When attaching the tabletop, using clamps during screwing is advisable to prevent shifting.
For cable management: A hole with a cable grommet in the tabletop is useful, especially for small desks, as it helps minimize cable clutter.
If you intend to place the desk closer to the wall, a strip on the back edge of the tabletop can help prevent tilting.
usbla schrieb:
For securing the panel, it is recommended to use clamps during screwingAbsolutely! I didn’t do that once, and later the panel shifted a bit, which was annoying. Clamps are the best helpers when screwing.
One more thing: For aesthetics, you can also cover the carcasses with film or paint them as you like – this breaks up the otherwise rather plain look of the cabinet and makes the desk a real eye-catcher.
Birepa schrieb:
What are the best Besta dimensions (height, width, depth) for a small desk?I think the question about dimensions is very important, but I would also like to emphasize ergonomics. The best dimensions are of little use if the desk is not adapted to your body measurements and the chair you use.
My suggestion:
- Calculate your optimal working height using a formula or reference values (e.g., elbow height when seated)
- Choose the Besta components so that they come as close as possible to this height
- If necessary: use height-adjustable table legs or add an extra board on top
Also, keep in mind that a small desk can get cluttered more quickly – when planning, make sure to include enough storage or surface space.
