ᐅ How can Ikea Pax wardrobes with sliding doors be easily cleaned?
Created on: 8 Mar 2023 14:07
DeomenelaoD
Deomenelao8 Mar 2023 14:07Hello everyone,
I have an Ikea PAX wardrobe with sliding doors at home and am currently facing the challenge of how to clean the sliding doors both effectively and easily. The doors are often made of wood or wood veneer, sometimes with glass or mirrors, and the bottom tracks also look somewhat delicate.
I am interested in specific cleaning tips that make the process efficient as well as gentle. Recommendations for particular cleaning products, suitable cloths, or tools to use for the track systems to avoid damaging the mechanism are also welcome.
Does anyone have experience with the care and cleaning of Ikea PAX sliding doors and can provide a clear, easy-to-follow guide? I want to avoid doors sticking, squeaking, or surface changes caused by incorrect cleaning methods.
Thanks in advance for your answers!
sarGabriel8 Mar 2023 14:19Hello,
for cleaning the PAX sliding doors, I recommend microfiber cloths and mild all-purpose cleaners. It is best to remove dust from the tracks with a brush and occasionally lubricate them with some silicone spray to improve sliding. Avoid using abrasive cleaners, as they can damage the surface.
Hello Deomenelao,
I had a similar PAX wardrobe with sliding doors, so I understand your situation. The most important thing is to know the exact material of the doors, as wood, laminate, glass, or mirrors each require slightly different cleaning methods.
- For wooden doors: A damp, soft cloth with a mild cleaning agent is usually sufficient. Avoid excessive water to prevent swelling.
- For glass doors: Use glass cleaner or a vinegar-water solution, but never spray directly onto the surface to avoid drips along the edges.
You should first remove visible dust and hair from the tracks. A vacuum cleaner with a narrow nozzle or a small brush works very well. Afterwards, a light lubricant such as silicone spray helps protect the rollers and improves sliding.
Important: Avoid oily or sticky substances, as they attract dust and worsen the mechanism. Regular cleaning of the tracks therefore helps prevent squeaking and sticking.
If you like, I can also provide a step-by-step guide for a clear overview.
Deomenelao8 Mar 2023 16:10Ramon4 schrieb:
You should first clean the tracks from visible dust and hair. A vacuum cleaner with a narrow nozzle or a small brush works very well.That sounds very helpful. I was worried about damaging the sliding tracks by applying too much force. Do you use the silicone spray directly on the tracks or on the rollers? And does Ikea offer any specific products you would recommend?
sarGabriel schrieb:
Avoid abrasive cleaners, as they can damage the surface.That makes sense. I often worry about cleaning too aggressively because the wood finish can quickly become dull.
For gentle cleaning of the Ikea PAX sliding doors, I recommend the following approach:
- Wipe the doors with a soft, lint-free microfiber cloth that has been lightly dampened with water.
- For more stubborn dirt, a solution of warm water and a mild, pH-neutral dishwashing detergent can be used.
- Never use aggressive cleaning agents such as ammonia, bleach, or abrasive pastes.
- For glass surfaces, a special glass cleaner applied with a soft cloth is suitable.
Regarding the sliding tracks:
- First, remove dry dirt using an old toothpick or brush.
- Apply a special silicone spray to the rollers (depending on the model, these may be visible or integrated within the track system) to maintain smooth sliding. Do not use oil, as it attracts dust.
To my knowledge, Ikea does not offer specific cleaning or lubricating products for the PAX system, so commercially available silicone sprays from retail stores are a good and cost-effective solution.
I would like to point out that in practice, many people criticize silicone spray because the fine residues can potentially impair the sliding mechanism over time.
Are sliding doors, due to their complex mechanics, possibly better maintained with a dry lubricant? For example, PTFE-based sprays, which attract less dust?
Additionally, cleaning intervals should be considered: Too frequent moisture exposure can damage the wood despite protective coatings, while too infrequent cleaning allows dirt to accumulate in the tracks, causing mechanical problems.
I find the track systems in PAX could be improved in terms of maintenance friendliness. Does anyone have experience with alternative cleaning methods or care products that ensure longer durability?
