ᐅ Handles, template, spacing, symmetry – frustration
Created on: 3 May 2016 19:19
Strahlemann-69
Hello everyone...
I can't decide how to install the handles... I have the template, but...
Some drawers are 10cm (4 inches), 20cm (8 inches), or 40cm (16 inches)...
I would like to lay the template flat and then use the lowest holes, but then it doesn't fit on the 10cm (4 inches) drawers...
I have chosen extra-wide handles...
Somehow, I'm stuck right now...
Nörgli
3 May 2016 23:40
At the local IKEA, I always grabbed the top handles from underneath. I also didn’t find it problematic with the slightly overhanging countertop.
Check how you would grip it.
IKEA-Freund
4 May 2016 00:19
I’d like to bring up the difference between the geometric center and the optical center... The latter is recommended for attaching handles, but of course, you should place your handles wherever you personally find most appealing. If you can’t decide: get two sets of cheap fronts (or have particleboard cut to size at your local hardware store) and try it out.
Personally, as an IKEA expert, I installed my handles at the geometric center of the narrowest front and placed all other handles at the same distance from the top edge.
IKEA-Freund
Nörgli
4 May 2016 08:39
Just flipped through the catalog... interesting how the handles on page 10 are NOT centered, but on page 13 (same kitchen, same spot?) they are, because that somehow looks better.
IKEA-Experte
4 May 2016 11:29
On page 10, it would not be possible to install the handles in the center and align them on the adjacent tall fronts with those on the narrow fronts. In that case, the handle on the tall fronts would sit on or just above the slopes of the panel.
Nörgli
4 May 2016 11:35
Yes, I see that. However, two pages earlier, the apparently same spot (close-up of the buffet cabinet in the same kitchen) has the handles centered.
IKEA-Experte
4 May 2016 11:56
This is definitely a different kitchen; it now has a blue tag attached.
Many images have been digitally assembled on the computer by now. Or the handles were moved digitally for close-up shots because it looks better.
