ᐅ Which handles are suitable for Ikea PLATSA?
Created on: 5 Nov 2024 08:17
Reo53
Reo53
5 Nov 2024 08:17
Hello everyone, I am planning to upgrade my Ikea Platsa cabinets with new handles and am currently a bit unsure about the options. Since the PLATSA series features a modular and flexible system with different fronts and sizes, it’s not entirely clear to me which types of handles work best here—both in terms of appearance and practicality. It is also important to me that the handles are easy to install and ideally match the existing drill holes on the PLATSA doors, so I don’t have to do much redrilling.
Has anyone had experience with specific handles for PLATSA and can offer recommendations? Which materials, shapes, or designs suit the modern but simple look particularly well? Are there any technical details regarding installation or handle alignment that should definitely be considered? Thanks for sharing your advice!
warrenka57
5 Nov 2024 08:45
Hello Reo53, I completely understand how challenging it can sometimes be to choose the right handles – I have replaced them several times myself and made a few mistakes along the way. For me, it is always important that the handles feel comfortable in the hand and have no sharp edges, especially if the cabinets are used frequently.
With PLATSA, I have had good experiences with simple, round metal handles that I could screw on without major modifications. However, I sometimes had to slightly adjust the position because the factory-drilled holes are not entirely universal.
I also like it when the handle color matches the frame of the door, as it creates a consistent overall look.
flo-Theres
5 Nov 2024 09:13
Hello Reo53,
I’m happy to provide some background information on installing handles for the PLATSA series, as this is often misunderstood. Most PLATSA fronts have a standardized drill hole spacing of 128 mm (5 inches), which generally makes handle installation easier. This means that many standard furniture handles with this hole spacing fit directly.
When choosing the type of handle, consider:
- Bar handles and bow handles are often the most suitable, as they align clearly with the drill holes.
- Push-to-open handles or concealed grip recesses are less commonly compatible, since the thickness and shape of PLATSA fronts are not always ideal for these solutions.
The choice of material mainly depends on the style: matte brushed stainless steel looks modern and is very durable, while wooden handles create a warmer design but are more prone to wear.
Tip: Do not tighten the handle screws too much to avoid damaging the front.
Palenar
5 Nov 2024 10:02
I would like to go a bit deeper into the topic and highlight some technical details and potential pitfalls when choosing handles for Ikea PLATSA. Basically, the most important measurement is the hole spacing (usually 128 mm (5 inches)), as already mentioned, but here are some additional details:
- PLATSA fronts often have a thinner thickness compared to traditional cabinet fronts. This means the screw length of the handles should be exactly matched to the front thickness. Screws that are too long can interfere on the inside.
- The drill holes on PLATSA are often centered on the narrow edge of the front, which can be problematic for some handle types if the handle requires a lot of grip space.
- In the DIY area, I prefer handles with a matte, powder-coated finish, as they are less prone to fingerprints and match the PLATSA look well.
- The distance to the top edge / side edge of the front is also important to achieve optimal ergonomics.
My question to you is: Which types of fronts are you using exactly (solid doors, drawer fronts, glass fronts) and how large are the cabinets? This will help specify the best handle choice.
Nabla64
5 Nov 2024 10:35
Regarding the topic "Which handles are suitable for Ikea PLATSA?" I would like to provide a brief guide on how to ideally proceed to make the right choice.
1. Check the measurements: As already mentioned, the hole spacing of 128 mm (5 inches) is the primary factor. It is best to measure your fronts carefully.
2. Consider the front material: PLATSA fronts come in various versions (MDF with foil, melamine, etc.) – the screw length and the handle curvature should match the material.
3. Choose the handle style:
- Bar handles: Easy to install, timeless, and ergonomic.
- Knob handles: Suitable if you prefer a more discreet look.
- Bow handles: Practical for larger doors or drawers.
4. Follow installation tips:
- Screws should not be too long.
- Pre-drilling is usually unnecessary since Ikea already provides the holes.
5. Appearance and material:
- Stainless steel and aluminum are durable and modern.
- Wooden handles create a warmer feel but require more maintenance.
Conclusion: For the most common PLATSA doors, I recommend matte black or brushed matte bar handles with a 128 mm (5 inch) hole spacing. These are easy to attach and suit many interior styles.
If anyone has specific front types or measurements, I am happy to assist further.
neoren
5 Nov 2024 11:02
Handle types for PLATSA should have a 128 mm (5 inch) hole spacing. Bar or bow handles are practical. Adjust screw length to the thickness of the front panel. Material: metal preferred – durable and easy to maintain.
