ᐅ Floor Plan Optimization for a 160 sqm Townhouse, approx. 145 sqm Usable Living Area
Created on: 9 Mar 2022 23:20
Pacmansh
We have purchased an end-terrace house from a developer and are currently in the phase where adjustments to the floor plan are still possible. The special aspect of this property is that it is not part of a repeated row house design but a unique build, allowing for somewhat more extensive modifications. The developer owns a plot on the outskirts of town, where three houses will be built: two multi-family buildings with condominiums and a block of three terraced houses. We purchased the easternmost one.
Adjustments are only possible inside due to the developer’s setup. The overall form and size of the house are fixed. However, many of the load-bearing walls, windows, etc., can be changed.
Plot size: approx. 270 sqm (2900 sq ft)
Slope: no
Floor space ratio
Built-up area ratio
Edge development
Number of parking spaces: 1
Number of floors: 2
Roof type: flat roof
Architectural style
Orientation: south
Maximum heights / limits
Additional requirements
Homeowners' Requirements
Architectural style, roof type, building type
Basement, number of floors
Number of residents, ages: 2 adults (40 and 35 years), 1 child (4 years), another child planned
Space needs on ground floor: kitchen / living / dining room, guest bathroom, utility room, storage room, office / guest room
Space needs upstairs: master bedroom, two children’s rooms, bathroom
Office use: limited home office, should also function as a guest room
Overnight guests per year: family lives further away; visits always include overnight stays, at least 2 overnight guests monthly
Open or closed floor plan
Conservative or modern design
Open kitchen, cooking island: yes
Number of dining seats: current dining table is 220 x 100 cm (87 x 39 inches), which works well for us
Fireplace: no
Music/stereo wall: not necessary
Balcony, roof terrace: yes, see floor plan
Garage, carport: no
Additional wishes / special features
Designed by:
- planner from a construction company / architect
I am referring to version 2, as it addressed some previously criticized points. We are quite satisfied with this plan but still have a few issues and hope for suggestions/ideas. Positive aspects:
- two equally sized children’s rooms upstairs
- larger bathroom than in version 1
- larger living/dining area, although it might still need to be reduced due to space requirements
- practical cloakroom solution
- the southern view. Our small garden is here, with a large field beyond it. The nearest tree in this direction is at least 200-250 m (650–820 ft) away.
What do you dislike? Why?
- guest bathroom on the ground floor lacks a shower
- office/guest room is very small
- missing a clear idea where a TV could go (not very important but something we’d like to consider)
Preferred heating system: an air-to-water heat pump will be installed; the exact location is still flexible.
If you must give up, which details/extensions
-can you do without: bathtub in the upstairs bathroom, slightly smaller living/dining/kitchen area, storage room on the ground floor (the only real storage space)
-cannot do without:
Version 1 was the original design from the project planner in the sales brochure. We requested a different layout for the heating/utility room, a somewhat less spacious staircase to gain space in the second children’s room, and a larger bathroom. The storage room should also be accessible from the hallway.
This led to the creation of version 2, with which we are fairly satisfied apart from the points mentioned above.
The planning is still somewhat informal at this stage. A formal planning meeting has yet to take place. An architectural firm will be involved to handle the detailed design. I get the impression that as much planning as possible is being done now since the current planners belong to the developer, and the architectural firm to be hired afterward would be “more expensive.” Overall, I must say that both before and after the purchase, our wishes have been fairly well accommodated and much is being made possible. For example, we were granted additional land area, a neighbor’s shed was moved to allow direct garden access, etc. I am not a professional but find the changes between versions 1 and 2 quite substantial for a developer purchase.
Do you see a way to create a guest bathroom with a shower and a larger work/guest room? Are there fundamental flaws in the floor plan?
Floor plan: ground floor/upper floor, terrace, roof terrace, outbuilding, dimensions and north arrow.
Ground floor plan with living/dining area, kitchen, terrace, hallway, bathroom, and storage rooms.
Upper floor plan with rooms 2–4, hallway, bathroom upper floor, and roof terrace.
Two-story floor plan of a house: ground floor/upper floor with rooms, kitchen, bathroom, hallway, and terrace.
Pacmansh
11 Mar 2022 08:26
kbt09 schrieb:
Floor-to-floor height is not the same as clear ceiling height. A floor-to-floor height of 305 cm (10 ft) will likely result in a maximum clear ceiling height of about 275 cm (9 ft).
That’s correct, I probably should have included that information right away. The floor-to-floor height on the ground floor is specified as 3.03 m (10 ft), the clear ceiling height on the ground floor is supposed to be 2.55 m (8 ft 4 in), and on the upper floor 2.47 m (8 ft 1 in).
gutentag schrieb:
Most houses without basements have a garage used as storage space. You could also consider enlarging the bike shed.
Yes, that’s on the list.
K a t j a11 Mar 2022 08:30
Pacmansh schrieb:
Right, I probably should have included that information directly. The floor-to-floor height on the ground floor is specified as 3.03 meters (10 feet), with a clear ceiling height of 2.55 meters (8 feet 4 inches) on the ground floor and 2.47 meters (8 feet 1 inch) on the upper floor.
That would mean a ceiling structure plus floor build-up of 48 centimeters (19 inches). What is that supposed to be—a bunker? Usually, it’s a bit over 30 centimeters (12 inches) total. I was already looking forward to a 2.70-meter (8 feet 10 inches) ceiling height for you…
Bertram100
11 Mar 2022 08:32
I think you’re worrying too much about storage space. “Somehow it always works out” means you manage to fit everything in. Floor-to-ceiling cabinets can hold a huge amount of stuff. I wouldn’t stress too much about it, let alone design the entire house around storage. A family of four doesn’t need four times as much storage as one or two people.
Most families get by just fine with a “normal” house with a regular amount of storage.
As a cyclist, I often find that bike parking is underestimated. But that’s just my opinion. Otherwise, I don’t quite understand your problem.
kbt09
11 Mar 2022 08:32
I also find that a bit much, but maybe a ventilation system or something similar is supposed to be integrated into the floor or ceiling construction.
With a floor-to-ceiling height of 305 cm (10 ft), I consider 17 steps to be quite ideal.
kbt09
11 Mar 2022 08:34
I agree with @K a t j a and @Bertram100 regarding storage space... It is very important to plan rooms in a way that allows standard-sized cabinets to be easily and discreetly accommodated. For example, using an entire wall for storage helps the cabinet blend in rather than standing out as a bulky piece in the room. Always make sure there is about 70 cm (28 inches) of space behind doors to make the wall suitable for placing a cabinet.
gutentag11 Mar 2022 08:35
K a t j a schrieb:
That would result in a ceiling plus screed thickness of 48cm (19 inches). What is that supposed to be – a bunker? Usually, the total thickness is a bit over 30cm (12 inches). I was already looking forward to your 2.70m (8 ft 10 in) ceiling height...
Then you have a maximum floor-to-floor height of 2.85m (9 ft 4 in), so 16 steps are enough. I also prefer a ceiling height of 2.75m (9 ft) myself.
