ᐅ Floor Plan Optimization for a 160 sqm Townhouse, approx. 145 sqm Usable Living Area
Created on: 9 Mar 2022 23:20
Pacmansh
We have purchased an end-terrace house from a developer and are currently in the phase where adjustments to the floor plan are still possible. The special aspect of this property is that it is not part of a repeated row house design but a unique build, allowing for somewhat more extensive modifications. The developer owns a plot on the outskirts of town, where three houses will be built: two multi-family buildings with condominiums and a block of three terraced houses. We purchased the easternmost one.
Adjustments are only possible inside due to the developer’s setup. The overall form and size of the house are fixed. However, many of the load-bearing walls, windows, etc., can be changed.
Plot size: approx. 270 sqm (2900 sq ft)
Slope: no
Floor space ratio
Built-up area ratio
Edge development
Number of parking spaces: 1
Number of floors: 2
Roof type: flat roof
Architectural style
Orientation: south
Maximum heights / limits
Additional requirements
Homeowners' Requirements
Architectural style, roof type, building type
Basement, number of floors
Number of residents, ages: 2 adults (40 and 35 years), 1 child (4 years), another child planned
Space needs on ground floor: kitchen / living / dining room, guest bathroom, utility room, storage room, office / guest room
Space needs upstairs: master bedroom, two children’s rooms, bathroom
Office use: limited home office, should also function as a guest room
Overnight guests per year: family lives further away; visits always include overnight stays, at least 2 overnight guests monthly
Open or closed floor plan
Conservative or modern design
Open kitchen, cooking island: yes
Number of dining seats: current dining table is 220 x 100 cm (87 x 39 inches), which works well for us
Fireplace: no
Music/stereo wall: not necessary
Balcony, roof terrace: yes, see floor plan
Garage, carport: no
Additional wishes / special features
Designed by:
- planner from a construction company / architect
I am referring to version 2, as it addressed some previously criticized points. We are quite satisfied with this plan but still have a few issues and hope for suggestions/ideas. Positive aspects:
- two equally sized children’s rooms upstairs
- larger bathroom than in version 1
- larger living/dining area, although it might still need to be reduced due to space requirements
- practical cloakroom solution
- the southern view. Our small garden is here, with a large field beyond it. The nearest tree in this direction is at least 200-250 m (650–820 ft) away.
What do you dislike? Why?
- guest bathroom on the ground floor lacks a shower
- office/guest room is very small
- missing a clear idea where a TV could go (not very important but something we’d like to consider)
Preferred heating system: an air-to-water heat pump will be installed; the exact location is still flexible.
If you must give up, which details/extensions
-can you do without: bathtub in the upstairs bathroom, slightly smaller living/dining/kitchen area, storage room on the ground floor (the only real storage space)
-cannot do without:
Version 1 was the original design from the project planner in the sales brochure. We requested a different layout for the heating/utility room, a somewhat less spacious staircase to gain space in the second children’s room, and a larger bathroom. The storage room should also be accessible from the hallway.
This led to the creation of version 2, with which we are fairly satisfied apart from the points mentioned above.
The planning is still somewhat informal at this stage. A formal planning meeting has yet to take place. An architectural firm will be involved to handle the detailed design. I get the impression that as much planning as possible is being done now since the current planners belong to the developer, and the architectural firm to be hired afterward would be “more expensive.” Overall, I must say that both before and after the purchase, our wishes have been fairly well accommodated and much is being made possible. For example, we were granted additional land area, a neighbor’s shed was moved to allow direct garden access, etc. I am not a professional but find the changes between versions 1 and 2 quite substantial for a developer purchase.
Do you see a way to create a guest bathroom with a shower and a larger work/guest room? Are there fundamental flaws in the floor plan?
Slope: no
Floor space ratio
Built-up area ratio
Edge development
Number of floors: 2
Architectural style
Orientation: south
Fireplace: no
Garage, carport: no
Designed by:
-cannot do without:
Nice-Nofret10 Mar 2022 20:22Of course, in Katja's design, you can also swap the living room and kitchen...
K a t j a schrieb:
Storage space mainly comes from the floor area needed for large cabinets. It is usually disadvantageous to plan many small rooms and niches where only tiny cabinets can fit. Such "little rooms" and those areas are then lost for other uses. Your argument becomes even clearer in your furnished floor plan. I have to agree with you there. I still find it hard to imagine that we’ll have enough space, but we’ll only find out by planning in more detail what exactly we want to accommodate. We’ll try to get a better overview of how much space we currently occupy over the weekend.
K a t j a schrieb:
A bathroom with 1 meter (3.3 feet) width won’t have a shower. That would be important for me with four people. If I were you, I’d pay attention to that as well. Exactly, I don’t want to miss out on that.
K a t j a schrieb:
But if the terrace doors are properly tall and wide, it doesn’t get dark inside. That’s why I found it okay. A narrow living room would have felt too cramped for me — but of course, that’s a matter of personal priorities. That was a really good point about planning the kitchen that way. I also see several advantages. I can’t say the window height yet, but currently there are two 2-meter by 2-meter (6.6 feet by 6.6 feet) windows and one 1-meter by 1-meter (3.3 feet by 3.3 feet) window planned. That could still be adjusted, and a larger sliding door would be possible, too. Having a view towards the garden while working is definitely great.
I now need to coordinate again with the architect and builder about who should plan which details at what stage. Construction work (earthworks) is scheduled to start mid to late summer if everything goes according to plan. I also don’t quite understand yet why from his side the house connections have to be on the right side of the house. Maybe because the bathroom on the upper floor and the kitchen are located there? Or maybe because he plans the outdoor unit of the heat pump there?
Wugler1978 schrieb:
Our neighbors’ house looks similar in terms of storage space. They also created an additional room under the closed staircase and are very happy with it.I once looked for pictures and will definitely keep that in mind.
The utility connections must come from the street, so here from the right side of the plan or the top of the plan. For a storage room, it might be possible to extend the bike shed, which can also be insulated.
The utility connections have to come from the street, so here from the right side of the plan or from the top of the plan. The utility connections also come from the top of the plan for the other corner house and the middle house. Therefore, I thought it would make sense to do the same for our house. However, the current architect is hesitant about this, and I don’t yet know why. But it should be possible to find out.
motorradsilke11 Mar 2022 06:51Pacmansh schrieb:
Actually, I meant "fear." We currently have a small attic compartment (sloped ceiling and not very high) and a basement room. We need to see how much space we will need. As Nida35a already mentioned, with a ceiling height of 3 meters (10 feet) in several rooms, I would install loft storage areas; that way, you have enough storage space for items you rarely use.
And with efficient use of space, you can also fit a larger shelf in the utility room.
