ᐅ Floor Plan Optimization for a 160 sqm Townhouse, approx. 145 sqm Usable Living Area
Created on: 9 Mar 2022 23:20
PacmanshHello,
We have purchased an end-terrace house from a developer and are currently in the phase where adjustments to the floor plan are still possible. The special aspect of this property is that it is not part of a repeated row house design but a unique build, allowing for somewhat more extensive modifications. The developer owns a plot on the outskirts of town, where three houses will be built: two multi-family buildings with condominiums and a block of three terraced houses. We purchased the easternmost one.
Adjustments are only possible inside due to the developer’s setup. The overall form and size of the house are fixed. However, many of the load-bearing walls, windows, etc., can be changed.
Plot size: approx. 270 sqm (2900 sq ft)
Slope: no
Floor space ratio
Built-up area ratio
Edge development
Number of parking spaces: 1
Number of floors: 2
Roof type: flat roof
Architectural style
Orientation: south
Maximum heights / limits
Additional requirements
Homeowners' Requirements
Architectural style, roof type, building type
Basement, number of floors
Number of residents, ages: 2 adults (40 and 35 years), 1 child (4 years), another child planned
Space needs on ground floor: kitchen / living / dining room, guest bathroom, utility room, storage room, office / guest room
Space needs upstairs: master bedroom, two children’s rooms, bathroom
Office use: limited home office, should also function as a guest room
Overnight guests per year: family lives further away; visits always include overnight stays, at least 2 overnight guests monthly
Open or closed floor plan
Conservative or modern design
Open kitchen, cooking island: yes
Number of dining seats: current dining table is 220 x 100 cm (87 x 39 inches), which works well for us
Fireplace: no
Music/stereo wall: not necessary
Balcony, roof terrace: yes, see floor plan
Garage, carport: no
Additional wishes / special features
Designed by:
- planner from a construction company / architect
I am referring to version 2, as it addressed some previously criticized points. We are quite satisfied with this plan but still have a few issues and hope for suggestions/ideas. Positive aspects:
- two equally sized children’s rooms upstairs
- larger bathroom than in version 1
- larger living/dining area, although it might still need to be reduced due to space requirements
- practical cloakroom solution
- the southern view. Our small garden is here, with a large field beyond it. The nearest tree in this direction is at least 200-250 m (650–820 ft) away.
What do you dislike? Why?
- guest bathroom on the ground floor lacks a shower
- office/guest room is very small
- missing a clear idea where a TV could go (not very important but something we’d like to consider)
Preferred heating system: an air-to-water heat pump will be installed; the exact location is still flexible.
If you must give up, which details/extensions
-can you do without: bathtub in the upstairs bathroom, slightly smaller living/dining/kitchen area, storage room on the ground floor (the only real storage space)
-cannot do without:
Version 1 was the original design from the project planner in the sales brochure. We requested a different layout for the heating/utility room, a somewhat less spacious staircase to gain space in the second children’s room, and a larger bathroom. The storage room should also be accessible from the hallway.
This led to the creation of version 2, with which we are fairly satisfied apart from the points mentioned above.
The planning is still somewhat informal at this stage. A formal planning meeting has yet to take place. An architectural firm will be involved to handle the detailed design. I get the impression that as much planning as possible is being done now since the current planners belong to the developer, and the architectural firm to be hired afterward would be “more expensive.” Overall, I must say that both before and after the purchase, our wishes have been fairly well accommodated and much is being made possible. For example, we were granted additional land area, a neighbor’s shed was moved to allow direct garden access, etc. I am not a professional but find the changes between versions 1 and 2 quite substantial for a developer purchase.
Do you see a way to create a guest bathroom with a shower and a larger work/guest room? Are there fundamental flaws in the floor plan?
Slope: no
Floor space ratio
Built-up area ratio
Edge development
Number of floors: 2
Architectural style
Orientation: south
Fireplace: no
Garage, carport: no
Designed by:
-cannot do without:
Without going into details at this late hour: I find option 1 more appealing and see more change than improvement in option 2.
Without going into detail at this late hour: I prefer option 1 and see more changes than improvements in option 2.I completely agree. Just a few comments: guest bathroom without a window, upper floor hallway without space for furniture, upper floor hallway with an unnecessary narrow extension leading to the bedroom, ...
That surprises me somewhat, but that’s exactly why I’m asking here. I’ll address a few points that bothered me about option 1.
Upper floor:
- The second children’s room (room 3) is very small at 10 m² (108 sq ft); it might have to be used as a guest room, with room 1 on the ground floor as the second children’s room, but I don’t really like that idea.
- The bathroom at 6.5 m² (70 sq ft) seems very small to me.
Do you see it differently?
Ground floor:
- I miss space for a coat area. The only spot I can think of is under the stairs, but that would become even smaller if the door to the storage/wardrobe room is placed facing the hallway.
- I feel there is not enough space on the right wall of the kitchen for tall cabinets.
- True, the window is definitely missing; I would also like to have a shower there.
- The narrow extension in the upper floor hallway could be closed off (dashed wall/door). If the staircase direction were changed, it might even be possible to create a small storage area along the wall to the upper room. However, I’m unsure how the staircase would then look on the ground floor.
Upper floor:
Ground floor:
SoL schrieb:
Just a few notes: guest toilet without a window, upper floor hallway without usable space, upper floor hallway with unnecessary narrow extension to the bedroom, …
