ᐅ Floor Plan Optimization for a 160 sqm Townhouse, approx. 145 sqm Usable Living Area
Created on: 9 Mar 2022 23:20
Pacmansh
We have purchased an end-terrace house from a developer and are currently in the phase where adjustments to the floor plan are still possible. The special aspect of this property is that it is not part of a repeated row house design but a unique build, allowing for somewhat more extensive modifications. The developer owns a plot on the outskirts of town, where three houses will be built: two multi-family buildings with condominiums and a block of three terraced houses. We purchased the easternmost one.
Adjustments are only possible inside due to the developer’s setup. The overall form and size of the house are fixed. However, many of the load-bearing walls, windows, etc., can be changed.
Plot size: approx. 270 sqm (2900 sq ft)
Slope: no
Floor space ratio
Built-up area ratio
Edge development
Number of parking spaces: 1
Number of floors: 2
Roof type: flat roof
Architectural style
Orientation: south
Maximum heights / limits
Additional requirements
Homeowners' Requirements
Architectural style, roof type, building type
Basement, number of floors
Number of residents, ages: 2 adults (40 and 35 years), 1 child (4 years), another child planned
Space needs on ground floor: kitchen / living / dining room, guest bathroom, utility room, storage room, office / guest room
Space needs upstairs: master bedroom, two children’s rooms, bathroom
Office use: limited home office, should also function as a guest room
Overnight guests per year: family lives further away; visits always include overnight stays, at least 2 overnight guests monthly
Open or closed floor plan
Conservative or modern design
Open kitchen, cooking island: yes
Number of dining seats: current dining table is 220 x 100 cm (87 x 39 inches), which works well for us
Fireplace: no
Music/stereo wall: not necessary
Balcony, roof terrace: yes, see floor plan
Garage, carport: no
Additional wishes / special features
Designed by:
- planner from a construction company / architect
I am referring to version 2, as it addressed some previously criticized points. We are quite satisfied with this plan but still have a few issues and hope for suggestions/ideas. Positive aspects:
- two equally sized children’s rooms upstairs
- larger bathroom than in version 1
- larger living/dining area, although it might still need to be reduced due to space requirements
- practical cloakroom solution
- the southern view. Our small garden is here, with a large field beyond it. The nearest tree in this direction is at least 200-250 m (650–820 ft) away.
What do you dislike? Why?
- guest bathroom on the ground floor lacks a shower
- office/guest room is very small
- missing a clear idea where a TV could go (not very important but something we’d like to consider)
Preferred heating system: an air-to-water heat pump will be installed; the exact location is still flexible.
If you must give up, which details/extensions
-can you do without: bathtub in the upstairs bathroom, slightly smaller living/dining/kitchen area, storage room on the ground floor (the only real storage space)
-cannot do without:
Version 1 was the original design from the project planner in the sales brochure. We requested a different layout for the heating/utility room, a somewhat less spacious staircase to gain space in the second children’s room, and a larger bathroom. The storage room should also be accessible from the hallway.
This led to the creation of version 2, with which we are fairly satisfied apart from the points mentioned above.
The planning is still somewhat informal at this stage. A formal planning meeting has yet to take place. An architectural firm will be involved to handle the detailed design. I get the impression that as much planning as possible is being done now since the current planners belong to the developer, and the architectural firm to be hired afterward would be “more expensive.” Overall, I must say that both before and after the purchase, our wishes have been fairly well accommodated and much is being made possible. For example, we were granted additional land area, a neighbor’s shed was moved to allow direct garden access, etc. I am not a professional but find the changes between versions 1 and 2 quite substantial for a developer purchase.
Do you see a way to create a guest bathroom with a shower and a larger work/guest room? Are there fundamental flaws in the floor plan?
Floor plan: ground floor/upper floor, terrace, roof terrace, outbuilding, dimensions and north arrow.
Ground floor plan with living/dining area, kitchen, terrace, hallway, bathroom, and storage rooms.
Upper floor plan with rooms 2–4, hallway, bathroom upper floor, and roof terrace.
Two-story floor plan of a house: ground floor/upper floor with rooms, kitchen, bathroom, hallway, and terrace.
kbt09
11 Mar 2022 07:18
Story height <> clear room height. A story height of 305 cm (120 inches) should result in a maximum clear room height of 275 cm (108 inches).
Story height is needed as a value for calculating, for example, stairs.
K a t j a11 Mar 2022 08:07
Pacmansh schrieb:
I still find it hard to imagine that the space will be enough for us, but we’ll only find out once we plan in more detail what we want to fit in. We’ll try to get a better overview this weekend of how much space we are currently using.
A good time for decluttering. Anything that hasn’t been used for more than 1 year can be reconsidered. 🙂
Pacmansh schrieb:
I can’t say the window height at the moment, but currently we have planned 2 windows of 2m (6.5 ft) each and one of 1m (3.3 ft). This could still be adjusted, a larger sliding door would also be possible. Having a view toward the garden while working is definitely great.
That would be one of the first things I’d want to clarify with the builder. For example, you could ask about patio doors with a transom window above.
gutentag11 Mar 2022 08:08
Pacmansh schrieb:
I also think it’s very good, but I’m a bit concerned about ending up with too little storage space. Besides, it’s always a bit difficult to break away from familiar patterns, but that’s what I’m here for.
Most people without a basement use a garage for storage. You could also consider enlarging the bike shed.
motorradsilke
11 Mar 2022 08:08
kbt09 schrieb:
Floor-to-floor height is different from clear ceiling height. A floor-to-floor height of 305 cm (120 inches) will likely result in a maximum clear ceiling height of about 275 cm (108 inches).
Floor-to-floor height is needed as a value, for example, to calculate stairs.
Okay. But even with 275 cm (108 inches), it is possible to install a loft or mezzanine in secondary rooms (guest room, bedroom) without compromising living quality, where you can store items like suitcases and decorations.
gutentag11 Mar 2022 08:15
Hello @K a t j a, you could reduce the number of steps by two. For a height of 3.05 m (10 feet), 17 steps are sufficient.
K a t j a11 Mar 2022 08:21
gutentag schrieb:
Hello @K a t j a, you could save two steps on the stairs. For 3.05 m (10 ft), 17 steps are sufficient.
Yes, I didn’t count the steps in the sketch. I always calculate the space requirements in advance using -> Stair 1x1. The illustration isn’t perfect – my software can’t do that.
