ᐅ Outdoor Water Connection from the Kitchen – Is It Possible?
Created on: 5 Sep 2016 22:43
netti
netti
5 Sep 2016 22:43
We forgot to include the exterior water tap in the special features list.
Now we had the idea to simply use the water connection in the kitchen and branch off to the outside wall. My question is whether this is that simple?
The distance from the water connection to the outside wall is about max. 2.5 meters (8 feet 2 inches). So the route would be quite short. The wall itself consists of 12.5 cm (5 inches) calcium silicate brick + 22 cm (9 inches) insulation + plaster.
I was thinking of running a hose in the kitchen and installing a separate valve there so that the branch can be closed during winter.
I would be very grateful for any ideas.
tomtom796 Sep 2016 02:01
These are called frost-proof fittings. I also added a pipe afterward from the bathroom to the outside at our place.
netti
6 Sep 2016 09:38
How much did the fun cost? With return flow or just one way?
tomtom796 Sep 2016 09:45
Approximately 2 meters (6.5 feet) of pipe from Viega plus pressing tool, drilling a hole through about 30cm (12 inches) of concrete, and 2 hours of labor plus Kemper frost proof valve.
280 euros plus VAT
In our case, the basement was still in the shell stage, so I only had to open a drywall partition.
Return flow? What for?
wrobel6 Sep 2016 10:04
Hello
In theory, this is possible.
However, it will most likely fail due to the sizing of the supply line.
Olli
netti
6 Sep 2016 10:10
wrobel schrieb:
Hello
In theory, that is possible.
It will most likely fail due to the sizing of the supply line.
Olli
Do you mean that the supply line in the kitchen will be too small?
