ᐅ Is it possible to connect Ikea Pax wardrobes across multiple rooms to create shared storage?
Created on: 1 Jun 2022 08:23
Fargla
Fargla
1 Jun 2022 08:23
Hello everyone, I have a question about the Ikea PAX system that has been on my mind for a while: Is it possible to connect or link multiple PAX wardrobes located in different rooms so that they function as a continuous storage space? I don’t only mean visually, but also in terms of usability—for example, whether it’s possible to create access as if they form one connected unit, or if there are practical solutions for such integrated use. I’m especially interested in whether the modular system can be flexibly combined across different rooms, so that instead of having completely separate furniture pieces, there is a seamless storage space that also makes sense in everyday use. Are there any experiences, tips for connection systems, or special constructions? Thanks for your insights!
RonJarrett
1 Jun 2022 09:44
Basically, the Ikea PAX wardrobes are designed as standalone modules. The individual units are standardized, so while they can be placed side by side and secured against tipping with connecting fittings, Ikea does not offer a continuous connection across multiple rooms, such as with a connecting element or a specially designed system feature.
In practice, connections through staggered arrangements or corner solutions are possible, for example within a single room or adjacent rooms with an open connection. For separate rooms, custom solutions would be needed, such as creating wall openings and individually made panels or connecting frames. However, this is significantly more complex both technically and structurally.
Palenar
1 Jun 2022 11:03
From my experience and a technical perspective: PAX systems are designed for modular use within a single room and are characterized by their flexibility in internal arrangement and customization. This means they can be configured individually, but physical connections across multiple rooms are not intended.
If you want to connect several rooms as storage space, the first question is what kind of connection you specifically want:
- Should it only appear as a unified system visually?
- Do you want to create some kind of passageway or open connection?
- Or do you want one piece of furniture to mechanically support another, for example, through screws or brackets?
For visual uniformity, I recommend configuring all PAX units with identical fronts, colors, and dimensions. This already creates a consistent appearance, even if the wardrobes are located in different rooms.
Mechanical connections, such as using brackets for stability, only make sense if the furniture pieces stand directly side by side. With separate rooms, this is generally not possible, unless structural modifications like a wall opening or some kind of passageway between the rooms are made.
If you are thinking of passageways, you could consider designing a niche between the rooms using PAX shelves accessible from both sides. However, the wall would need appropriate openings for this. This is not a standard feature of Ikea, but rather a tenant modification or remodeling.
If you want to modify the PAX carcass itself, this will be difficult without personal initiative or custom-made parts, as Ikea does not provide continuous rails or other connecting components.
Fargla
1 Jun 2022 12:12
Thanks for the information; it already helps to clarify things. My idea was really not to remove any walls but rather to create a single unit using special connecting brackets or possibly a continuous floor solution, so that the cabinets are firmly connected without gaps, even if they are separated by, for example, an open door. Another possibility could be a shelving system that runs like a line through two, possibly adjacent rooms, so that you still have separate rooms but the impression of one large storage space.
Does anyone have experience with precisely fitting components that can be added by yourself to achieve something like this? Or has anyone ever tried to perfectly align and connect PAX wardrobes using laser levels or similar tools to create a seamless row?
Timmyse36
1 Jun 2022 14:05
Your idea sounds exciting, and I can easily understand the desire for a continuous storage solution, almost like a wall that also provides storage space. However, in such a case, I would pay close attention to stability and usability, especially if the cabinets are fixed together and located in two rooms separated by a door.
Sometimes small issues arise with door movement or cleaning and accessibility. Particularly when the connection between the furniture is rigid, problems may occur over time, for example if the floors in the rooms are not exactly level or the walls are slightly misaligned.
My recommendation would be to carefully consider whether the connection remains flexible enough, or if it might be better to prioritize visual consistency and place the individual parts separately but designed to look similar. Still, I think the idea is great, and if you feel confident, give it a try!
puvin
1 Jun 2022 15:55
Oh, I find this really interesting! The idea of connecting storage spaces across different rooms is truly innovative! You could create something really great with that.
Maybe you could try something like this using custom-made connectors? For example, strong metal brackets or wooden elements that serve as linking pieces between the PAX units. It would definitely be important to ensure everything stays stable and doesn’t shift, as it needs to withstand some load.
I would also consider non-slip materials on the floor, in case the cabinets are not fully secured with screws.
Perhaps there are better solutions or someone who has completed a similar project with Ikea cabinets? I’m really curious if anyone else has managed to realize this kind of idea!
