ᐅ What modifications can be made to the Pax system to increase storage space?
Created on: 7 Apr 2021 09:07
Ernestomu
Hello everyone, I am currently focusing on optimizing my Pax wardrobe to create as much additional storage space as possible without having to buy completely new furniture. I am particularly interested in practical adjustments that can be made to the Pax to better utilize the existing space. Possible options include adding shelves, extra hooks, drawer systems, or even interior modifications to better accommodate specific items. What experiences have you had with modifications that have significantly increased storage capacity? I would also appreciate tips on suitable products or DIY ideas. Thanks in advance for your constructive suggestions!
Ernestomu
7 Apr 2021 16:15
Thank you all for your suggestions so far! I especially appreciate the point made by BAUEVA – I will definitely take that into account in my planning. One more specific question for everyone: Does anyone have experience installing inner drawers that you build yourself or with alternatives outside of the Ikea range? I ask because I sometimes find the standard options too expensive or stylistically not a good match for the rest. Are there any tips here for sturdy, affordable DIY systems or alternatives made of wood or metal that work well?
tangi
8 Apr 2021 09:47
Self-built drawers can be a great alternative if you have some DIY skills. Drawers with slides from the furniture fittings range, which can be purchased separately, are recommended—both metal runners and ball bearing slides. Custom-cut wood (for example, plywood) that is carefully sanded gives a high-quality impression and can be tailored to fit the Pax dimensions. It is important to consider the maximum load capacity of the wardrobe frame, so it is better to use lightweight materials. This way, you can gain storage space and customize the look.
semuneo
8 Apr 2021 10:35
That sounds like a great project, tangi. I also think it’s important to feel truly comfortable with such renovations since you use the cabinet every day. Maybe a tip if you’re doing it yourself: try testing the drawer movement first using cardboard as a prototype to see if everything fits smoothly before you invest a lot of time in building. I’ve done similar tests myself and avoided quite a few mistakes – it saves a lot of stress!
Declan55
8 Apr 2021 11:12
For DIY drawers, I have often used thin plywood sheets plus metal runners. It’s affordable and doesn’t look bad at all, especially if you line the interior with film, like non-slip mats. This keeps everything in place and prevents drawer contents from shifting. Also, when you build the drawers yourself, you can tailor the dimensions perfectly to your individual needs. It’s a great way to create flexible storage space!
Ernestomu
8 Apr 2021 13:00
Thank you for all the detailed tips here! Your contributions are very helpful in looking at the topic from different angles. Finally, do you think that the conversions you described could realistically lead to a significant increase in usable space (for example, 20-30% more room)? Or is it more a matter of better organization and clarity? I want to set realistic expectations here before making a major investment.
Sinan-meo
8 Apr 2021 13:35
That is a very valid question, Ernestomu. Realistically, with well-planned modifications, you can expect about 15-25% more usable storage space when the area is optimized and organization is improved. This, of course, varies depending on the initial situation – the less structured the closet was before, the greater the gain. At the same time, overall clarity improves significantly, which adds more long-term value to the usability. In short, storage space and organization go hand in hand.
