ᐅ Which DIY projects can be done using IKEA Hemnes furniture?
Created on: 10 Apr 2020 09:37
ELSABAR
I’m currently diving into DIY projects related to furniture and have come across the IKEA Hemnes series. Since these pieces are often used as a base for customizations due to their classic look and sturdy construction, I’m curious:
What specific DIY projects can be done with IKEA Hemnes furniture? I’m not just talking about simple changes like painting or new handles, but also functional modifications, upcycling ideas, or even complex rebuilds that transform Hemnes pieces into completely new furniture.
Maybe some of you have experience or know of good inspirations that go beyond the usual tweaks while remaining practical and durable. Are there any special considerations regarding material quality or assembly that should be kept in mind for such projects?
Looking forward to your ideas and experiences!
kulau
11 Apr 2020 08:19
In my experience, a solid understanding of the construction of Hemnes furniture is crucial when using it for complex DIY projects. Here are some technical notes based on my work with Hemnes dressers:
- The components mostly consist of solid pine wood panels combined with MDF back panels and glued elements
- The joints are partly made with dowels and screws; caution is needed when disassembling to avoid compromising stability
- For modifications, such as integrating LED lighting or electrical components, I recommend precise measurements and drilling with depth control to prevent damaging the wood
Question for ELSABAR: What kind of projects do you want to focus on specifically? Are you aiming more for furniture modifications or looking for complete new creations based on Hemnes?
ELSABAR
11 Apr 2020 09:04
Thanks for the responses so far!
kulau schrieb:
Question for ELSABAR: What kind of projects do you want to focus on specifically? Are you aiming more at modifying individual furniture pieces, or are you looking for complete new creations based on Hemnes?
Good question! I think I’m aiming for a middle ground—projects where I don’t just alter Hemnes furniture on the surface but integrate functional innovations, without attempting complete redesigns. For example, a Hemnes cabinet equipped with built-in charging options or adjustable interior layouts.
The furniture should remain sturdy and suitable for everyday use after modification, not a shaky DIY job. Beyond the basic framework, I prefer affordable, practical solutions rather than relying on too many specialized tools or professional craftsmanship.
GLAEL
11 Apr 2020 09:56
For your project, Hemnes dressers are well suited for adding drawers with cable openings and power outlets. Folding or removable work surfaces are also easy to implement.
Pay attention to the dimensions of the handles and install power strips compatible with the internal measurements. This maintains stability and enhances functionality.
BAUEVA
11 Apr 2020 11:30
One more thought on this topic:
ELSABAR schrieb:
integrate functional innovations without attempting complete redesigns.
This is important because DIY enthusiasts often underestimate the technical adjustments required when expanding functions, especially with socket or electronic installations in wood.
To ensure the furniture remains stable, screw connections should always be reinforced and existing channels for electrical wiring should be properly used or minimally expanded. Otherwise, weak points can develop quickly.
gipifa
11 Apr 2020 12:47
Hey, I find Hemnes really exciting for DIY projects because with a bit of care and the right tools, you can create some really cool things! My tip: try converting a small sideboard – with new paint, adding casters, and a few pull-out compartments inside. It’s a lot of fun, and the furniture ends up looking almost custom-made!
Plus, a DIY project like this is very motivating and you get a unique piece for your home. So grab the screws, you can do it!
RETRAVIS
11 Apr 2020 13:23
Conclusion based on the above points:
- Hemnes furniture provides good potential for modular adaptations due to its pine wood construction
- Functional extensions are feasible but require careful planning and some level of craftsmanship
- To integrate energy-related components (e.g., electrical systems), appropriate tools and knowledge are important to avoid compromising the structure
In conclusion, before making any modifications, I recommend thoroughly inspecting the chosen piece of furniture and, if necessary, researching specific Hemnes modifications in detail online to ensure that no critical load-bearing or connection elements are unintentionally damaged.
