ᐅ Preliminary floor plan design for a 220 m² single-family house
Created on: 20 Jun 2017 22:41
R.Hotzenplotz
Hello!
We have already gone through several plans with our architect and I think we are almost there, about to start the detailed planning phase. Before that, I’m looking forward to getting feedback from other users.
Development plan/restrictions: §34 – two full stories
Plot size: 1,085m² (1,1679 yd²)
Basement, floors – 2 full stories plus partial basement
Number of people, ages – 3 people (37, 34, 1, second child planned)
Space requirements on ground floor and upper floor – the requirement was that bedrooms and the study should be about 17m² (183 ft²) each; the entire house should be approximately 220m² (2,368 ft²)
Office: family use
Guests per year: 1
Open or closed architecture: closed
Traditional or modern design: modern
Open kitchen, kitchen island – no open kitchen, but yes to a kitchen island
Number of dining seats – 6
Fireplace – yes
Music/stereo wall – TV wall
Balcony, roof terrace – balcony
Garage, carport – large garage
Additional wishes/special features/daily routines, preferably with reasons why certain things should or should not be included – everyone should be able to sleep as undisturbed as possible in their bedrooms, even if other family members are awake. The husband is sometimes up as early as 4 a.m. Otherwise, watching TV in the evening should be possible without disturbing those sleeping upstairs.
Who created the design:
- Architect (freelancer for a general contractor)
What do you like most? Why?
The upper floor with well-sized rooms and the location of the rooms exactly where they should be (only the washroom area we would still like to move to the outer right corner so that you don’t have to pass it every time you use the toilet). On the ground floor, the access through an airlock, the kitchen, and the dining area with the study next to it are especially liked.
Also appreciated is that after adjustments, the study now faces the garden instead of the street.
What don’t you like? Why?
We originally wanted the distance from wall to wall where the sofa and TV stand is to be about 6.40m (21 ft) (large screen & surround system), but so far only 5.69m (19 ft) has been realized.
Laundry room as described.
Kitchen larger in square meters than needed; the approx. 3m² (32 ft²) could theoretically be used well in the living area.
720,000 euros (including construction incidentals)
Personal price limit for the house, including equipment:
800,000 euros
Preferred heating technology:
Gas
If you have to give up on something, which details/features can you do without?
- Can do without:
Technical systems like controlled residential ventilation
- Cannot do without:
Space (except for the kitchen)
Why is the design the way it is now? For example:
Is this a standard design from the planner?
The architect has largely implemented our wishes; the only issue is the living room situation.
Patient, quick to implement, has already gotten to know us well.
No negative points.
Do you notice any other points that might not fit or that we should consider, which we might have overlooked?
In the basement, the room currently labeled as home cinema might possibly be used as one medium- to long-term. For the foreseeable future, it will be a storage room.
Office: family use
Guests per year: 1
Fireplace – yes
800,000 euros
Gas
- Can do without:
No negative points.
R.Hotzenplotz27 Jun 2017 23:0711ant schrieb:
A home theater with a toilet flush is a sign of poor planning, and you should really give him a hard time about it.So basically, the entire plan needs to be redone from scratch? Or how can we fix this?
R.Hotzenplotz schrieb:
So basically, start the entire planning process over again? Or how do we fix this? No. By poor planning, I only meant the drainage. I don’t quite understand the corner cut out above the sofa on the upper floor from the building’s form, but objectively, that’s not a defect.
It’s time to decide whether the kitchen should face the front or the back, with a straight or angled wall. The rest is just diligently working through the conclusions from the discussion.
The architect prefers the recessed solution from the outside and the straight solution from the inside..... difficult..... Difficult? – Unnecessary to open a new can of worms at this point. Among you, your spouse, and the architect, there needs to be more calm about which house is actually going to be built. At the conceptual level of the building form, your ideas are still too far apart.
Therefore, it might be worth clarifying whose idea this passage corner for the breath of the dragon god on the upper floor actually is, and why(?)
R.Hotzenplotz27 Jun 2017 23:59We are practically finished. Only the detail regarding the living room will be finalized by tomorrow. The kitchen has long been settled.
Regarding drainage, I’m not sure what else I should tell the architect. He says everything is feasible and that I shouldn’t worry. Since I’m not a specialist, I won’t contradict that now.
We have thoroughly addressed the points from the discussion. It has been very helpful! Many thanks to all participants at this point.
Regarding drainage, I’m not sure what else to tell the architect. He says everything is doable and that I shouldn’t worry about it. I’m not an expert, so I can’t really argue the opposite. Feasibility is not in question. As the client, you are indeed knowledgeable, and as such, you should say: "Säckel, you’ve been caught planning poorly. Now fix it properly and don’t ever do that again."
R.Hotzenplotz28 Jun 2017 00:04He also said that... no need to worry, he will take the appropriate soundproofing into account during the detailed design phase. This could then be included in the construction contract.
