ᐅ Preliminary floor plan design for a 220 m² single-family house
Created on: 20 Jun 2017 22:41
R.Hotzenplotz
Hello!
We have already gone through several plans with our architect and I think we are almost there, about to start the detailed planning phase. Before that, I’m looking forward to getting feedback from other users.
Development plan/restrictions: §34 – two full stories
Plot size: 1,085m² (1,1679 yd²)
Basement, floors – 2 full stories plus partial basement
Number of people, ages – 3 people (37, 34, 1, second child planned)
Space requirements on ground floor and upper floor – the requirement was that bedrooms and the study should be about 17m² (183 ft²) each; the entire house should be approximately 220m² (2,368 ft²)
Office: family use
Guests per year: 1
Open or closed architecture: closed
Traditional or modern design: modern
Open kitchen, kitchen island – no open kitchen, but yes to a kitchen island
Number of dining seats – 6
Fireplace – yes
Music/stereo wall – TV wall
Balcony, roof terrace – balcony
Garage, carport – large garage
Additional wishes/special features/daily routines, preferably with reasons why certain things should or should not be included – everyone should be able to sleep as undisturbed as possible in their bedrooms, even if other family members are awake. The husband is sometimes up as early as 4 a.m. Otherwise, watching TV in the evening should be possible without disturbing those sleeping upstairs.
Who created the design:
- Architect (freelancer for a general contractor)
What do you like most? Why?
The upper floor with well-sized rooms and the location of the rooms exactly where they should be (only the washroom area we would still like to move to the outer right corner so that you don’t have to pass it every time you use the toilet). On the ground floor, the access through an airlock, the kitchen, and the dining area with the study next to it are especially liked.
Also appreciated is that after adjustments, the study now faces the garden instead of the street.
What don’t you like? Why?
We originally wanted the distance from wall to wall where the sofa and TV stand is to be about 6.40m (21 ft) (large screen & surround system), but so far only 5.69m (19 ft) has been realized.
Laundry room as described.
Kitchen larger in square meters than needed; the approx. 3m² (32 ft²) could theoretically be used well in the living area.
720,000 euros (including construction incidentals)
Personal price limit for the house, including equipment:
800,000 euros
Preferred heating technology:
Gas
If you have to give up on something, which details/features can you do without?
- Can do without:
Technical systems like controlled residential ventilation
- Cannot do without:
Space (except for the kitchen)
Why is the design the way it is now? For example:
Is this a standard design from the planner?
The architect has largely implemented our wishes; the only issue is the living room situation.
Patient, quick to implement, has already gotten to know us well.
No negative points.
Do you notice any other points that might not fit or that we should consider, which we might have overlooked?
In the basement, the room currently labeled as home cinema might possibly be used as one medium- to long-term. For the foreseeable future, it will be a storage room.
Office: family use
Guests per year: 1
Fireplace – yes
800,000 euros
Gas
- Can do without:
No negative points.
R.Hotzenplotz24 Jun 2017 02:02So, should we now finally decide if there will be any changes to the windows shown in the plans?
It might be worth considering moving the laundry room window higher for the sake of the rear facade’s appearance, so it aligns better with the windows of the bathroom, dressing room, and bedroom.
R.Hotzenplotz schrieb:
So should we now finally decide where changes are still needed for the indicated windows? Sure: yes. I would also create a list showing how often each window size appears and how many different sizes are on the same facade. The first helps to identify where similar but not identical windows might have been planned by mistake; the latter is important for the overall visual harmony. It’s also important not to forget to consider two adjacent elevations together.
R.Hotzenplotz24 Jun 2017 02:2411ant schrieb:
Clearly: yes. I would also make a list showing which window sizes appear how often and how many different sizes are used on the same facade. The first helps to identify where similar but not identical sizes might have been planned unintentionally; the latter relates to the overall visual uniformity. It’s important not to forget to also consider two adjacent sides together.But this is definitely the kind of issue where the architect would advise you personally or not. So far, we’ve never really discussed windows—only that, in principle, we don’t want any floor-to-ceiling windows except for the patio and balcony doors. And only afterwards, when we noticed something, have we looked at it... so there has been no “strategic approach” to the windows until now.
R.Hotzenplotz24 Jun 2017 09:54Ibdk14 schrieb:
I like the plans. I would have preferred the kitchen facing the garden, but that’s your decision. I would make the door from the garage to the pantry wider. It could get tight if you want to carry shopping boxes through there.We also liked both versions and spent days considering them. For us, the study is less of a business space and more of a living area, so the view of the garden fits better. I’m curious how the architect will address the small drawback of the narrow passage from the kitchen to the dining area.
Thanks also for the tip about the garage door. I just added that to the revision notes I sent last night. Very helpful!
