ᐅ Do you have any tips for preventing loose fittings in KALLAX units in a home office?
Created on: 7 Jan 2020 09:42
DURSUNDEO
Hello everyone, I hope you can help me with my problem. In my home office, I use several KALLAX shelving units from IKEA with the typical square inserts, where I store various items and books. Unfortunately, I have noticed that some of the inserts become increasingly loose over time and no longer fit properly, which affects stability and also looks untidy. Do you have any tips or tried-and-tested solutions for securing the inserts so they don’t become loose? I would really appreciate it if you could share your experiences, especially regarding mounting methods or alternative options you have already tried.
Hey DURSUNDEO, I think KALLAX is great for a home office, but the inserts can be a bit annoying with wobbling sometimes 😅. For my shelves, I used felt pad strips – simply glued them to the inside edges. It holds really well, and if you want to change something, you can just peel them off easily without any hassle. Plus, the pads add a touch of coziness – less clattering noise when sliding things in and out. 😉
Give it a try, it worked wonders for me!
It should also be considered that the stability of KALLAX shelves largely depends on how they are installed. Especially on uneven floors, the furniture can easily warp, causing the inserts to become loose. Therefore, a level base is essential.
Furthermore, I recommend securely fastening and checking the back panel of the shelving unit. A firmly attached back panel adds stability to the frame and thus improves the support for the inserts.
If you lose multiple inserts at the same time, this could also indicate a general weakness of the model or wear and tear due to age.
DURSUNDEO8 Jan 2020 12:10vin_leo schrieb:
Used felt pad strips – simply glued on the inside edges. Holds really well and if you want to change something, you can just peel them off without any hassle.That sounds great, especially since I want to be able to swap out the inserts flexibly. How thick are those strips usually? I want to avoid putting too much tension on the inserts, which could potentially stress the wood.
@KIN42: Thanks also for the tip about the back panel and the base. The shelf is actually on a somewhat soft floor covering, so the idea of a solid foundation makes sense. I’ll check that out right away.
One small note: When using adhesive pads or felt strips, you should consider their load capacity. If the inserts are heavily loaded, these aids might fail.
For heavier loads, this could be an argument for mechanical fastening, such as screws and brackets, as suggested by PLOMA. Otherwise, flexible adhesive methods are typically sufficient. Temperature and humidity in the room can also have an effect – KALLAX is MDF-based, and this material tends to swell slightly when exposed to moisture, which can affect the fit.
I just realized how frustrating it is when seemingly simple furniture starts causing problems after a while. Thanks to everyone for your helpful tips!
I’d like to add that even when considering possible fixes, I would prefer a solution that alters the original condition as little as possible. I especially appreciate vin_leo’s suggestion of using felt pads, as they are flexible and help prevent fiddling and pressure marks.
In situations like this, it’s also important to stay calm and periodically level the furniture, because sometimes the wobble is caused by us or the floor, and the furniture itself isn’t really defective—just has some minor quirks.
