ᐅ Even with careful assembly, the Kallax still wobbles slightly – why?
Created on: 18 Oct 2024 09:13
keemilia39
I recently assembled a Kallax shelf from IKEA and despite careful assembly, it wobbles slightly when gently tapped or lightly loaded. I have checked all screws multiple times, the individual parts are positioned exactly as they should be, and I have followed the assembly instructions meticulously. However, there is still some noticeable instability, especially when the shelf is empty or only lightly filled.
I would like to understand: Why does the Kallax shelf wobble slightly despite careful assembly? Is it due to the design, the material, or typical Kallax construction methods? Are there any tips or specific measures to significantly improve its stability? I appreciate any objective advice.
blapau
18 Oct 2024 14:47
klo61 schrieb:
The shelf is basically designed as a lightweight, modular piece of furniture
Exactly, that is important to understand. The design deliberately focuses on modularity and easy assembly, rather than absolute durability. For improved stability, I recommend additionally using brackets to secure it to the wall and fixing the back panel with stronger screws.
Another tip: If the shelf needs to carry heavier loads, it makes sense to install extra reinforcement elements such as L-brackets between the back panel and the base, if possible. This significantly increases torsional rigidity.
Filippo
18 Oct 2024 16:08
I would like to add some technical details regarding the cause of wobbling:
The construction method of Kallax uses particle board or MDF panels with a thickness of 15 or 16 mm (0.6 inches), which are held together with tongue-and-groove joints and metal screws. This often allows for slight play because the drill holes and insertions have some tolerances. These accumulate into a noticeable slight movement.
Furthermore, the material deforms somewhat elastically under load, especially during transport or with temperature fluctuations. The foil coating additionally causes tiny marks at the screw holes in some cases, which weakens the stiffness.
The fact that the back panel is often only nailed or stapled and does not form a continuous brace adds extra flexibility.
To solve the problem, the following is recommended:
- Replace the back panel with a thicker plywood board or reinforce it additionally.
- Use metal brackets and screws for wall mounting.
- Adjust leveling feet if the floor is not completely even.
Have you taken these points into account, or would further assistance in selecting the right reinforcement be helpful?
keemilia39
18 Oct 2024 17:59
Filippo schrieb:
To solve the problem, it is recommended to replace the back panel with a thicker plywood board or to reinforce it additionally.
Thank you for this detailed explanation. The back panel in the Kallax is indeed only simply stapled; I was wondering if greater stability could be achieved through other measures.
I haven’t attached it to the wall yet, but that sounds like a sensible next step.
How complex is it to retrofit a thicker back panel? Do I need special tools, or can this be done relatively easily as a DIY project?
Filippo
18 Oct 2024 18:22
Replacing the back panel is doable if you have some basic DIY skills.
You will need a plywood sheet the size of the back panel—ideally 4 or 6 mm (about 0.16 or 0.24 inches) thick, which can be cut to size at a hardware store. Then carefully remove the old back panel and attach the new one using small screws or nails. A cordless drill, screws, and a screwdriver are sufficient; nails and a hammer are alternatives.
Important: The plywood sheet should be positioned to fully cover the frame and stabilize the sides. If necessary, you can also attach small brackets on the inside corners.
Otherwise, it’s not a major task and significantly increases stability. If the back panel feels stable and straight after installation, the job is usually done.
GALEO4
18 Oct 2024 20:33
And that’s exactly the catch! Kallax is more of a stylish display unit by design than a true heavy-duty piece of furniture. Anyone who assumes that an easy assembly also guarantees maximum stability doesn’t understand the concept.
My recommendation is always: if you want it truly solid, replace the chipboard material with plywood, reinforce all joints, and secure the shelf to the wall. Anything else is just wishful thinking.
Kallax isn’t a pine shelf from grandpa’s time, but a compromise for modern, fast use.
keemilia39
19 Oct 2024 08:49
GALEO4 schrieb:
Kallax is not a pine wood shelf from Grandpa, but a compromise for modern, quick use.
I agree with that now. In my household, I prefer a slightly wobbly shelf that is functional and inexpensive over something that takes several days to assemble and adjust.
Still, it would be nice if the stability could be improved with minimal effort—such as simpler wall mounting without much drilling or stronger back panels, as Filippo suggested.
Does anyone have experience with specific products for supporting or stabilizing shelves that noticeably improve stability without major modifications?
