ᐅ Do you have any tips for preventing loose fittings in KALLAX units in a home office?
Created on: 7 Jan 2020 09:42
DURSUNDEO
DURSUNDEO
7 Jan 2020 09:42
Hello everyone, I hope you can help me with my problem. In my home office, I use several KALLAX shelving units from IKEA with the typical square inserts, where I store various items and books. Unfortunately, I have noticed that some of the inserts become increasingly loose over time and no longer fit properly, which affects stability and also looks untidy. Do you have any tips or tried-and-tested solutions for securing the inserts so they don’t become loose? I would really appreciate it if you could share your experiences, especially regarding mounting methods or alternative options you have already tried.
PLOMA
7 Jan 2020 10:27
First of all, that’s a smart question, because the KALLAX system is popular, but the inserts are not always perfectly stable. When inserts become loose, the problem is often the fit of the shelves or the connector joints. It is important to carefully check whether the inserts are correctly positioned before attempting any fixing: some inserts have small plastic corners or guides that need to fit precisely. Once these are properly seated, you can use additional adhesive pads, such as foam rubber strips or double-sided tape at the contact points. This provides light holding power without damaging the inserts.
Another option is to mount small brackets inside with individual screws. Although this is more labor-intensive, it ensures lasting stability, and you can still remove the inserts. It is important not to drive the screws too deep to prevent the wood from splitting.
Are the inserts made of wood or plastic? Depending on the material, there are different treatment options. If it is plastic, small Velcro strips attached to the sides might help – this keeps the inserts fixed invisibly without glue.
I would also like to know: Can you describe the material and the condition of the inserts more precisely? And how heavily do you load the inserts? That would allow for more precise advice.
Elijah42
7 Jan 2020 11:09
I have had good experience with double-sided mounting tape for loose KALLAX inserts. Simply stick it on the inner edges; it holds well and still allows you to remove the inserts.
batabe
7 Jan 2020 12:45
Hello! I completely understand how frustrating it is when the inserts become loose. My first recommendation is to check whether the inserts are properly seated in the grooves. Sometimes the material rubs against the groove, or the insert might be slightly warped. It can also help to swap the inserts with some spares if you have any, or remove them for a few days and inspect the shelf unit.
If that doesn’t help, I have found that small felt pads applied to the inside of the inserts improve their fit and prevent them from tilting. The felt pads don’t stick firmly; they just provide gentle cushioning and ensure a secure fit.
Additionally, make sure the shelf carcass is standing flush and not rocking—this usually increases the loosening. Adding a few wedge-shaped supports under the feet often provides greater stability.
DURSUNDEO
7 Jan 2020 14:23
Thank you for the detailed response, PLOMA. The inserts are mostly made of particleboard with a thin veneer layer, so wood. They are actually quite sturdy, but in some places, there is a slight wobble. In everyday use, they mainly hold books and a few decorative boxes, nothing heavy.
The idea of using angle brackets sounds interesting. I am just a bit hesitant about drilling into the carcass. Has anyone had experience with whether this remains safe for IKEA-style materials?
Additionally, I would be interested in hearing if you have recommendations for less invasive methods, such as adhesive techniques that can be removed without residue, so that I can flexibly change the inserts if needed.
PLOMA
7 Jan 2020 15:01
DURSUNDEO schrieb:
The idea of using angle brackets sounds interesting. I’m just a bit hesitant about drilling into the cabinet.
I completely understand that! Drilling is often discouraged, especially to avoid reducing the value of the furniture piece. My practical recommendation is to use small, self-adhesive metal or plastic angle brackets. While they don’t have the strength of screwed brackets, they generally hold better than double-sided tape alone.
DURSUNDEO schrieb:
Adhesive techniques that can be removed without leaving residue
In that case, transparent, removable double-sided tapes or hook-and-loop pads are a good choice. For example, 3M offers solutions that adhere strongly yet can be cleanly removed later. This way, you can secure inserts without damaging the material. It’s important to test the adhesive and materials beforehand in an inconspicuous spot, since some veneers can be sensitive.
If reversibility is very important to you, I would advise against permanent adhesives or nails.
