ᐅ Wall bracket for Kallax breaks – what are the alternatives?
Created on: 12 Feb 2015 08:24
Sonba
I mounted a Kallax shelf on the wall, but unfortunately the wall bracket has repeatedly broken after some time – despite careful installation according to the instructions and using the provided screws. The shelf is well loaded with books and decorations, but not overloaded beyond what it should handle. Now I am looking for more stable or alternative wall mounting solutions that are safer and can hold the shelf without it eventually falling or the bracket failing.
What experiences have you had with wall mounts for Kallax? Are there other mounting methods or even alternative installation systems I could try? It is important to me that the solution does not require significant damage to the wall (so not too many anchor holes, etc.) and, of course, is reliably stable.
I appreciate any tips!
Sonba
12 Feb 2015 10:35
Thank you very much for the advice!
Regarding the questions:
The wall is standard brickwork (not drywall). I used the supplied anchors (a standard plastic anchor set from IKEA) and four screws per shelf (two on the bottom and two on the top for each mounted bracket). The shelf holds about 80-100 kg (175-220 lbs) of books and decor, spread out, but nothing particularly large or unbalanced.
The breaks in the bracket always occurred at the point where the shelf hooks onto the bracket – sometimes the bracket shifted slightly or even cracked the wood on that side.
I have considered using a crossbar, but I am hesitant due to the additional effort and extra drilled holes – that’s why the idea of free, no-drill solutions also sounds interesting to me if something stable is possible.
Do I need to use special heavy-duty anchors for brick walls? And are there particular brackets that are more robust than the original IKEA ones?
TEBILO
12 Feb 2015 10:51
Sonba schrieb:
So, do I need to use special heavy-duty anchors for a brick wall?
Definitely yes! Plastic anchors from IKEA are usually designed only for light loads. For brick, I recommend Fischer or similar heavy-duty anchors (e.g., Fischer SX or UX) that anchor deeply and securely into the masonry.
Sonba schrieb:
Brackets sturdier than the originals?
Yes, there are steel brackets with a larger surface area that you can find marketed as shelf brackets. Some DIYers also use angle brackets from hardware stores with 4 or more screws per bracket instead of two. This greatly increases the mechanical stability.
For the cracks in the wood, I would recommend additionally screwing wooden slats to the shelf, to which the brackets can then be attached. Or, even better, build a separate sturdy wall support with metal angles that provides extra reinforcement for the shelf.
If you want, I can gladly provide you with a step-by-step guide including a drawing or a detailed parts list.
NAU34
12 Feb 2015 11:13
Sonba schrieb:
The idea of free, drill-free solutions sounds interesting to me if something stable could be achieved that way.
To be honest, without drilling and anchors it quickly becomes critical with heavy shelves like Kallax. I know shelves held by strong adhesive tapes, but that’s not a long-term solution—more of a temporary fix and only for light loads :-)
My advice: It’s better to make a few extra holes and have a shelf that stands like a rock. You can always paint over the holes afterwards, and they hardly show. Plus, the peace of mind that nothing will come crashing down is definitely worth it ;-)
LUSIN
12 Feb 2015 11:26
A small tip: When attaching the shelf to a brick wall, always use a rotary hammer drill in hammer mode. This creates clean holes that hold the anchors securely.
Also, make sure the screws are long enough to penetrate deeply into the anchor and provide a firm grip.
If you are using IKEA brackets, check whether the mounting holes on your Kallax shelf are already slightly worn, which can weaken the hold. If so, applying some glue and adding small wooden dowels often helps to secure the bracket better.
BLAKEO
12 Feb 2015 11:38
TEBILO schrieb:
Some DIY enthusiasts also use brackets from the hardware store with four or more screws per bracket instead of two
That sounds reasonable. However, I wonder if having more screws not only makes the bracket more stable but also better distributes the load onto the wall.
Maybe this could be improved by placing a thin aluminum plate as a load distributor between the shelf and the bracket? This would help spread the pressure more evenly and minimize point loads on the wood and the wall.
What do you think?
Sonba
12 Feb 2015 11:52
BLAKEO schrieb:
maybe this can be improved by placing a thin aluminum plate as a load distributor between the shelf and the bracket?
That sounds interesting! Could something like that really improve the stability of the Kallax wood at the hook point? I assume that the wood there gets stressed and then cracks due to the pressure at the screw connection.
Maybe you could also screw a thin plywood sheet to the back of the shelf to increase the load-bearing capacity of the mounting points, similar to a reinforcement. Would you recommend doing that?
