I am facing a rather annoying problem with my IKEA Kallax shelf. Several of the connection screws that hold the shelf together have stripped heads, so I can no longer unscrew them. The shelf is supposed to remain stable, but without these screws, that is of course difficult.
My question: Are there any tried-and-true methods to replace or remove such stripped Kallax screws without damaging the furniture? I am specifically asking about replacement solutions because some IKEA spare parts are not easily available, and there are many different types of screws used.
Has anyone had similar issues, maybe with tips on alternative types of screws or tools that could help? Should the whole shelf be reassembled differently, or are there special threaded inserts that would fit?
I look forward to your suggestions and thank you in advance!
Hello Mathew2,
I am very familiar with the problem of stripped screw heads in Kallax shelves; it can happen quickly if too much torque or the wrong tool is used.
First of all: if the screw is completely broken off, drilling it out with a special left-hand drill extractor is often the only solution – this is a tool that bites into the screw and turns it out. However, you need to be careful not to damage the shelf wood.
Another option is to try gripping the screw with a pipe wrench or locking pliers if part of the screw shaft is still protruding.
Regarding replacement screws: Kallax screws are usually metric (M4 or M5) with specific lengths, but compatible options are often available at hardware stores. Make sure the screws match in material and thread type.
If you want to make proper use of the existing holes, thread inserts (Helicoils) are a good alternative. This way, you can renew the damaged threads and install new screws with the correct torque.
Good luck, and feel free to ask if you need more details on any step!
Hey Mathew2,
too bad you ruined the screw heads – but hey, I guess we’ve all been there! 😅
My first suggestion would be to see if you can grip the broken screws with some patience and gentle force using locking pliers, if they are still sticking out a bit. If not, a screw extractor is definitely your friend – it works like magic. 🎩✨
For new screws, go for ones with a slightly thicker core so this doesn’t happen again. Oh, and very important – a torque wrench will help prevent damage next time.
Also, you can improvise with threaded inserts, which are affordable and will make the shelf stable again.
Good luck and let us know how it goes! 🙂
SETHBLA schrieb:
Drill out the screw, use a left-hand screw extractor, otherwise get new screws from the hardware store. Thread inserts are not a bad idea.Exactly – that’s the practical summary, but I wanted to add some context since many might not be familiar with this.
One more tip: When drilling, start with a small drill bit for the center to avoid damaging any valuable threaded holes in the shelving. It’s better to proceed in several small steps rather than using force.
Also, after the repair, always check that everything is properly tightened without any play – this maintains stability.
In short: Buy a locking plier, a left-handed extractor, and new screws.
But honestly, who hasn't experienced this: a screw gets stuck and suddenly breaks off. The only solution is calmness, patience, and a bit of DIY skill 🙂.
And remember – the assembly situation can sometimes be as frustrating as the problem itself. Maybe try tackling it with a cold coffee in hand, and it’ll work out! 😉
