ᐅ Why do the doors on the Kallax units always hang crooked?
Created on: 28 Jun 2019 08:22
Trato
I have installed doors on several Kallax shelving units from Ikea, and I keep noticing that the doors never hang perfectly straight. They always seem to be slightly crooked or warped, so they don’t close flush.
So my question is: Why do the doors on Kallax units always hang crooked? Are there structural reasons related to the shelving or the doors themselves? Or is it due to the installation, the hinges, or possibly material warping? I’m interested if anyone has solid experience or knows the causes, because this issue is repeatable for me and particularly annoying during use, as it looks unsightly and the doors don’t close properly.
I’m grateful for any explanations, tips for fixing this, or advice!
Neogi
28 Jun 2019 09:11
Jonna schrieb:
The tolerances in the construction of the basic shelf are relatively generous
This is a key point. Ikea relies on mass production with simplified specifications here.
RON57 schrieb:
Material type: MDF or particleboard can expand when exposed to moisture
I would like to discuss this further: MDF generally reacts less strongly to moisture than particleboard, but the melamine coating can cause asymmetric stresses if moisture penetrates only one side.
Additionally, it is worth questioning how much the base influences this. Not only the horizontal plane is important, but also the vertical stability of the walls.
Who has reliable experience with measures that have helped reduce or prevent warping?
Trato
28 Jun 2019 09:19
RON57 schrieb:
Material type: Kallax carcasses are made of MDF or particleboard[...] material can warp
Thanks, that seems reasonable, especially the note about moisture.
Jonna schrieb:
The doors are made of MDF, which swells or shrinks with humidity changes
Could it be that the doors are more prone to this while the shelving unit itself remains more stable?
I have the unit standing on a fairly level floor, but the wall behind it is not perfectly straight.
Are there any recommendations on how best to adjust the hinges? Is this a time-consuming process, or can it be done systematically? I really want to avoid the doors staying permanently misaligned.
RON57
28 Jun 2019 09:31
Trato schrieb:
Are there any recommendations on how to best adjust the hinges?
Yes, I’m happy to explain:
Kallax doors come with standard cam hinges, which usually offer three adjustment options:
1. Depth adjustment: Turn the screw on the side of the hinge to bring the door closer to or further away from the cabinet.
2. Height adjustment: Sometimes done via screws behind the hinge pin or through elongated holes that allow the hinge to be moved slightly up or down.
3. Lateral adjustment: A screw that shifts the door left or right.
The best approach is to initially hang the door roughly, then make each adjustment step by step, checking the effect after each change. It’s best to turn one screw slightly, then close the door and check again.
Since the adjustment range for Kallax is limited, this requires some patience, but it can significantly improve misalignments.
Chendu
28 Jun 2019 09:45
The hinges are, as mentioned, adjustable.
If the alignment is really off, it often helps to check the cabinet carcass to ensure it is properly screwed or assembled straight.
Sometimes the panels are slightly warped, which means the doors can never be perfectly aligned.
Fitigu
29 Jun 2019 10:09
In addition to the previous answers:
The door position on the Kallax is determined by the exact placement of the hinge drillings in the carcass. Ikea manufactures with certain tolerances, as production is highly optimized for large quantities. However, the drillings are not always perfectly square to the carcass surface, which can promote misalignment.
Furthermore, the limited adjustability of the hinges themselves within the guide rails is restricted. Therefore, noticeable deviations cannot be ruled out.
In addition, the static load caused by the door itself must be considered: The MDF doors carry a certain weight load at the hinge point due to the material, which can affect alignment over time through slight deformations of both components – door and carcass.
Neogi
30 Jun 2019 12:17
Fitigu schrieb:
The door position is determined by the exact placement of the hinge drilling holes in the cabinet body
Exactly, and this also means that any tolerances in the drilling pattern become visible over time – especially with inexpensive mass-produced products.
However, I think this issue is often underestimated because people tend to suspect the hinges or the assembly instead.
How do you handle it if the door is extremely misaligned and adjustments no longer help? Replacement? Redrilling? Sanding down the corners?
