ᐅ Are there any alternatives if inserts do not fit in the KALLAX unit?
Created on: 23 Jul 2022 09:13
Jonathon
Hello everyone, I have a question that has been on my mind for some time and I’m hoping for an active discussion here in the forum: Are there any practical alternatives if the inserts for the IKEA KALLAX shelving unit don’t fit in terms of size or functionality?
I really like using the KALLAX because of its flexibility, but especially with drawer or cabinet inserts, I’ve noticed that the standard options often don’t fully meet my requirements, whether it’s regarding height, interior layout, or special features.
Have you found your own solutions, perhaps alternative suppliers or even DIY projects that integrate well with the KALLAX? How do you handle the issue when the available inserts don’t fit exactly?
sanjon
23 Jul 2022 12:45
I often rely on flexible third-party inserts specifically designed for KALLAX. These are usually modular and can be combined. If that doesn’t fit, cutting custom inserts from durable plastic yourself also works well.
Jonathon
24 Jul 2022 08:34
Thanks already for the many helpful tips and experiences shared so far.
@Nakar33: You mentioned the material load – could you please explain in more detail which limits I should consider regarding weight and load capacity for KALLAX in such custom builds? I would also like to know how different materials (wood, plastic, fabric boxes) affect this.
Additionally, I am interested if anyone here has experience with a combination of original IKEA inserts and self-made components, so-called "hybrid solutions."
Nakar33
24 Jul 2022 09:57
Jonathon schrieb:
You mentioned material load – could you explain in more detail what limits I should consider regarding weight and load for KALLAX when doing DIY builds?
The KALLAX shelves themselves are quite sturdy, but the shelves and compartments are designed to hold about 13–15 kg (29–33 lbs).
When using custom constructions, you should especially pay attention to the stability of the materials: plywood or MDF with a thickness of at least 9–12 mm (0.35–0.47 inches) is recommended. Plastic should have sufficient wall thickness to prevent sagging. Also, keep in mind: the heavier the material used, the less total load you can carry overall.
Jonathon schrieb:
Experiences with hybrid solutions
I use these often myself: IKEA wood or metal inserts work very well combined with custom-made flexible dividers made from acrylic or wood. It is important that the inserts fit well to avoid wobbling within the compartments. A precise custom fit or adding hook-and-loop strips can be helpful here.
barle
24 Jul 2022 10:33
In summary: measure precisely, choose lightweight materials, and if necessary, combine IKEA inserts with custom-built components. This way, the shelf is more stable and the inserts fit better.
lubla
24 Jul 2022 11:08
One more tip: For versatile use, plastic boxes from brands like Really Useful Box are also suitable. You can fit them exactly into KALLAX compartments, and they often come with practical lids and dividers.
NOAHSAU
24 Jul 2022 11:44
barle schrieb:
Measure precisely, choose lightweight materials, and combine IKEA inserts with custom builds if needed
That’s exactly the point: Why do all the work when IKEA already offers suitable products?
I often find it excessive to build everything custom or constantly switch between DIY and prefabricated parts just because it doesn’t “fit 100%.” That’s exactly the problem with the idea of “one shelf for everything.”
