ᐅ Are there any alternatives if inserts do not fit in the KALLAX unit?
Created on: 23 Jul 2022 09:13
Jonathon
Jonathon
23 Jul 2022 09:13
Hello everyone, I have a question that has been on my mind for some time and I’m hoping for an active discussion here in the forum: Are there any practical alternatives if the inserts for the IKEA KALLAX shelving unit don’t fit in terms of size or functionality?
I really like using the KALLAX because of its flexibility, but especially with drawer or cabinet inserts, I’ve noticed that the standard options often don’t fully meet my requirements, whether it’s regarding height, interior layout, or special features.
Have you found your own solutions, perhaps alternative suppliers or even DIY projects that integrate well with the KALLAX? How do you handle the issue when the available inserts don’t fit exactly?
barle
23 Jul 2022 09:47
If the inserts for the KALLAX do not fit, you can use boxes or baskets that have precisely measured dimensions. Alternatively, it often helps to customize with small dividers to suit your individual needs.
Nakar33
23 Jul 2022 10:22
barle schrieb:
If the inserts don’t fit in the KALLAX, you can use boxes or baskets instead
It’s especially worth measuring carefully here because although KALLAX may seem standardized, there can be slight variations depending on the production batch.
An alternative is modular drawer inserts made of wood or plastic, which can be customized to the shelf dimensions and the desired compartment sizes. These can either be DIY projects or purchased from specialized furniture accessory suppliers. Be sure to pay close attention to the internal height, as even a few millimeters (inches) difference can be crucial for proper fit and function.
You might also consider using flexible organizer elements that can be moved or rearranged to serve various purposes. For example, well-stocked craft or office supply stores now often carry dividers or grids suitable for this use.
The most important thing is that the material is not too heavy so that the KALLAX shelf remains well balanced under load.
funon5
23 Jul 2022 11:05
The question is very sensible and important! I have personally searched extensively for alternatives to KALLAX inserts, as the standard options are often too rigid.
A good alternative is custom-cut inserts made from lightweight plywood, which you can order online from specialized wood suppliers. You can sand and paint them yourself on site to visually match the KALLAX.
Additionally, I recommend flexible compartments with adjustable dividers, which you can find, for example, in larger home improvement stores. This way, you can change the internal layout according to your needs.
If you don't feel confident building something yourself, there are also companies that produce custom-made inserts – a bit more expensive, but very precise in fit.
NOAHSAU
23 Jul 2022 11:38
funon5 schrieb:
A good alternative are custom-made inserts from lightweight plywood
Hmm, I actually find that unnecessarily complicated. KALLAX is designed specifically for standard solutions. If someone wants something different, they might as well consider a different shelving unit.
Maybe the whole approach is wrong: why not simply use what IKEA offers and possibly complement it with decorative crates or storage boxes? The market is large enough to find suitable items.
The effort to create something custom usually ends up reducing flexibility.
draFrederi
23 Jul 2022 12:07
I think DIY solutions offer a great deal of room for creativity. 🙂
Who says KALLAX has to be fitted only with typical IKEA inserts? There are great guides online on how to create custom inserts from MDF boards or even old wine crates.
You can also brighten up the overall look with fabric boxes in various colors and adjust them according to your mood.
So: there are alternatives; you just have to discover them and do a bit of crafting – in the end, it’s really fun!
