ᐅ After rearranging, my KALLAX shelf never sits completely flush against the wall—any ideas?
Created on: 2 May 2023 08:17
Naugenevi2
Hello everyone, I rearranged my KALLAX shelf, but I noticed that the back never sits flush against the wall – there is always a small gap at the back, no matter how I position it. Now I’m wondering if this is normal or if there is a way to adjust or align the shelf so that it sits directly against the wall. I’m using it in the living room, the wall is straight and the floor is level, but the gap remains. Has anyone else experienced this or have any tips to eliminate this space? Thanks in advance!
angel
2 May 2023 16:02
Hello!
Regarding your question about the soft floor: A carpet cushions and significantly affects stability. The carpet acts like a spring, which can cause a rocking motion. This means that the shelf will naturally lean slightly away from the wall at the back, even if the wall and floor are perfectly level.
About the adjustable feet: IKEA actually offers the "LURÖY" feet or the "Ekby" series, which can also be fitted to KALLAX to compensate for unevenness. Some IKEA enthusiasts also recommend placing felt furniture pads under the feet if you want to avoid scratches.
Good luck!
baupau
2 May 2023 16:24
I would add: In addition to adjustable feet, small wedges or rubber buffers can also help minimize gaps. Simply placing them underneath often easily resolves minor spacing issues.
Naugenevi2
3 May 2023 08:37
Thanks for all the tips so far! Today I set up the shelf without the carpet, and it is indeed closer to the wall now, but still not perfectly flush; there remains a tiny gap of about 2-3 mm (0.08-0.12 inches).
vinpau schrieb:
a narrowly cut piece of wood glued to the back
That sounds interesting—how did you attach the wood? With screws, glue, or double-sided tape? And are there specific dimensions or materials you would recommend to avoid damaging the back panel?
I don’t want to damage it in case I want to rearrange it later.
Surela
3 May 2023 10:12
Naugenevi2 schrieb:
How did you attach the wood?
I would recommend avoiding screws to prevent damaging the back panel. Instead, thin wooden strips (e.g., spruce wood 5x10 mm (0.2x0.4 inches)) and double-sided mounting tape are suitable, as the tape adheres strongly but can be removed relatively cleanly.
Alternatively, there are special plastic furniture wedges that can be glued to the back, which then protrude slightly to adjust the spacing. Important: Clean the back panel thoroughly before attaching, so the adhesive sticks better.
A 2–3 mm (0.08–0.12 inch) gap is quite normal if the wall isn’t perfectly flat. Some people place small rubber or felt strips behind the back panel to protect the shelf’s rear and to compensate for the space.
toril
3 May 2023 11:48
One brief note: To ensure the shelf is not only visually flush with the wall but also secure and stable, it is important to check whether the shelf is tip-resistant. Especially if there is a gap between the wall and the shelf, fastening it with screws or attaching brackets to the wall could be considered—even though the KALLAX normally does not require wall mounting.
If the gap can remain minimal for aesthetic reasons and no stability issues arise, using wooden strips or adhesive felt pads is sufficient.
V
vinpau
4 May 2023 07:59
That's exactly what I did! Double-sided tape is really great; it allows me to take the shelf down at any time without much effort.
Naugenevi2 schrieb:
Are there any specific dimensions or materials you would recommend to avoid damaging the back panel?
I used simple wooden strips from the hardware store, brown spruce wood about 1–2 mm (0.04–0.08 inches) thick and 10 mm (0.4 inches) wide. It holds really well and makes the shelf much more stable right away.
Good luck, you can do it! 🙂
