ᐅ BILLY shelf doors still squeak after lubrication – what are the next steps?
Created on: 4 Feb 2020 19:37
altan
altan
4 Feb 2020 19:37
I have lubricated the doors on my Billy shelf again to eliminate an annoying squeaking noise. Unfortunately, the squeaking still occurs even though I applied WD-40 and some silicone oil to both the joints and the hinges.
My question is: What further steps can I take to permanently eliminate the noise? Could the material of the shelf itself be the cause, or are there specific methods or products that might be more effective?
I would like to avoid replacing the doors completely. So, what can I do if lubrication doesn’t help and the squeaking persists?
barsar
4 Feb 2020 20:04
First, check if the screws on the hinges are tight. Loose screws can cause squeaking. If that doesn't help, try using graphite powder instead of oil.
LEVI41
4 Feb 2020 21:11
altan schrieb:
What additional steps can I take to permanently eliminate the noise?
Permanently stopping the squeaking on BILLY bookshelf doors usually requires a combination of proper lubrication, cleaning, and possibly replacing damaged parts.
1. Check screws and tighten or replace them if necessary.
2. Thoroughly remove old lubricant residues (use alcohol or acetone carefully).
3. Use a dry lubricant such as graphite or PTFE spray, as these do not become sticky.
4. Check whether the hinges are bent or warped.
If the persistent problem is due to material wear, replacing the hinges might be advisable. BILLY uses simple steel hinges, which can be swapped for higher-quality alternatives.
LEEJU
4 Feb 2020 22:03
I often see people only lubricating superficially. You should remove the doors, fully detach the hinges, and carefully oil and clean every part. Spraying from the outside usually is not enough.
Rhett
5 Feb 2020 07:18
Leeju schrieb:
Remove the doors, completely loosen the hinges, and carefully oil every part
Exactly. You need to allow the entire hinge to move freely; otherwise, the squeaking noise will persist.
lis64
5 Feb 2020 08:09
If you want to analyze the problem more thoroughly, also check the attachment of the door to the shelving unit itself. Sometimes a misaligned door presses against the wood and causes noises that sound like squeaking.
