ᐅ Why do BILLY doors often creak?
Created on: 7 Mar 2021 08:12
TOKE56
TOKE56
7 Mar 2021 08:12
Hello everyone, I have recently noticed that the doors of my BILLY shelf often creak when I open or close them. I'm wondering: why do BILLY doors creak so frequently for many users? Is this a known issue related to the hardware quality, or is it more due to the assembly, humidity, or perhaps the material itself? I would like to understand what exactly to watch out for in order to prevent or fix the creaking. Perhaps someone here has long-term experience with BILLY and knows the typical causes.
boelnu
7 Mar 2021 08:35
I can fully understand how annoying creaking doors are – I had the same issue with my BILLY shelf.
In my experience, it’s often due to a combination of hinge quality and lack of lubrication. Especially with older models, dust and small particles get trapped in the hinges, which often makes the movement quite rough.
Sometimes a bit of oil or silicone spray helps, but that is really just a short-term solution when the material itself is gradually wearing out.
kinsi
7 Mar 2021 09:02
Simply spray the hinges with some WD-40, and the squeaking will usually go away. If not, replace the hinges.
ronti
7 Mar 2021 09:27
Squeaking usually occurs due to friction between metal parts or between metal and wood. Therefore, lubrication or replacing the hinges often solves the problem easily.
Wesley
7 Mar 2021 10:11
Haha, I can just imagine a BILLY shelf secretly creaking when the door opens, as if it’s trying to say, "Hey, watch out, I’m under tension!" 😄
But seriously: most of the time, it’s really the combination of metal fittings and lack of lubrication. And since BILLY is more of an affordable shelf, the hardware doesn’t exactly get a luxury vacation. 😉 A little oil, and the doors will slide smoothly again.
Elias
7 Mar 2021 11:45
I had the same problem at first and was quite frustrated because the creaking was so loud that you hardly dared to use the door.
Wesley schrieb:
Most of the time, it really is the interaction between metal bearings and lack of lubrication.
This matches my experience exactly. I thoroughly cleaned the hinges, applied some silicone spray, and that helped a lot. It’s also important to tighten the screws because sometimes they loosen.
