ᐅ BILLY shelf doors still squeak after lubrication – what are the next steps?
Created on: 4 Feb 2020 19:37
altan
I have lubricated the doors on my Billy shelf again to eliminate an annoying squeaking noise. Unfortunately, the squeaking still occurs even though I applied WD-40 and some silicone oil to both the joints and the hinges.
My question is: What further steps can I take to permanently eliminate the noise? Could the material of the shelf itself be the cause, or are there specific methods or products that might be more effective?
I would like to avoid replacing the doors completely. So, what can I do if lubrication doesn’t help and the squeaking persists?
Lisele
5 Feb 2020 20:43
That sounds really frustrating, especially after trying several methods. 🙂 I had a similar problem once – in the end, switching to silicone spray helped me. You’ve probably already tried this, but maybe completely remove the old residues first and make sure it ventilates properly? I’m keeping my fingers crossed that you’ll have peace soon!
Roberta
6 Feb 2020 06:30
LEVI41 schrieb:
Use of dry lubricants such as graphite or PTFE spray
I would also recommend that. WD-40 often works only temporarily and attracts dust, which causes the squeaking to return.
chenfi
6 Feb 2020 08:52
If the squeaking continues even after lubrication, it might be due to a material defect. Check whether the hinges are smooth and clean at the contact points, or if there are any rusty or damaged areas. Sometimes, simply replacing the hinges with a more modern model helps.
