After using my Billy shelf for several years, I’ve noticed that the doors increasingly squeak when I open or close them. I’m curious about the most common causes of this squeaking in Billy shelves.
I have already tried lubricating the hinges, but without much success. Maybe it’s related to the adjustment or another component?
I would be very grateful for helpful tips, especially if you can explain how to identify and fix the possible causes yourself.
Hello KNUT34,
your question about squeaky doors on the Billy bookshelf is very well asked. The most common causes can usually be divided into three areas:
1. Hinge mechanics: Billy bookshelves use simple press-in or clip-on hinges, which can become dry or dirty over time. Careful cleaning and occasional lubrication with a suitable lubricant, such as silicone spray or sewing machine oil, can help. I would only recommend WD-40 in exceptional cases, as it can be too aggressive.
2. Hinge adjustment: If the hinges are incorrectly adjusted—often installed too tight or at an angle—this can cause friction that leads to squeaking. Check the gap between the door and the shelf to see if everything is aligned evenly.
3. Material fatigue and looseness: Over time, small movement or stress cracks can develop in the wood or connection points. This is often noticeable if the door panel wobbles slightly or no longer closes precisely.
In summary: clean, lubricate, adjust, and if necessary, perform minor repairs on the wood. I am happy to provide detailed instructions if you need help with any of these steps.
Interesting point, klabe, but I think the topic of lubricants should be considered more carefully. Not every oil is truly suitable. Especially with inexpensive furniture like Billy, the wrong lubrication can cause dirt to stick even more and worsen the problem.
Has anyone had experience with dry lubricants or special Teflon sprays? These might have a longer-lasting effect without leaving aggressive residues.
silako schrieb:
Not every oil is really suitable.That is absolutely correct, so I always choose a lubricant that is light and non-sticky. Dry lubricant is a good alternative, especially for frequently used furniture parts like doors.
A simple step-by-step guide:
1. Remove the door from its hinges and clean the hinges with a dry cloth.
2. Apply the lubricant thinly and evenly.
3. Reinstall the door and open and close it several times to distribute the lubricant evenly.
If the squeaking still persists afterwards, check whether the hinges have play or need to be replaced.
