Created on: 11 Sep 2018 07:32
rick2018
Now a bit about me:
Greetings from Swabia
Now a bit about me:
rick2018 schrieb:
Run your finger over the display glass of your phone and then over the exposed concrete.
That’s the difference. The ground and polished walls feel like smooth, clean glass. The question is which appearance and texture you want to achieve. What I find so nice about concrete is its versatility. It can be as smooth as glass or have a textured surface like formwork patterns, and can be either rough and raw or glossy and refined.
I’m sure you already have the desired result clearly in mind.
Best regards! mini_g!
sichtbeton8227 Dec 2019 22:53We are very satisfied with our concrete surfaces (ceilings and some walls)! A small tip: Make sure that, for example, the plasterer and/or painter uses proper masking tape on the concrete surfaces (if necessary). We now have some tape residue on the concrete. We hope that since the tape was grease-free, the residue is only moisture and will no longer be visible soon, but you can point this out in advance!
Otherwise, as always: an awesome place! Wishing you continued success!
Today, I quickly primed 300m2 (ceilings and walls where no insulation will be applied) in the garage with a white primer. The topcoat will go on tomorrow. If time and motivation allow, I might also prime one of the utility rooms and the storage room. Currently, there are hardly any installations in place, so there is not much masking to do...
The plan worked
The garage received its topcoat today, and the technical room and storage area have been primed.
Since the question about the paint comes up from time to time:
- Primer: StoPrim Color white
- Topcoat: Sto Silco G AW15
Applied with a Wagner PowerPainter 90. The primer was diluted about 2%, the facade paint about 5%.
Here is a (partial) picture with still wet paint:
