Created on: 11 Sep 2018 07:32
rick2018
Now a bit about me:
Greetings from Swabia
Modern villa with flat roofs, terraces, glass surfaces, green surroundings – several views.
rick201824 Dec 2019 01:13
@guckuck2 Our large wall in the stairwell and the stairs were delivered as exposed concrete with impregnation. However, I want the surface to be even smoother and to remove the dirt. Therefore, we will polish it again. Afterwards, a renewed impregnation is advisable.
guckuck2
24 Dec 2019 09:21
rick2018 schrieb:
@guckuck2 Our large wall in the stairwell and the stairs were delivered as exposed concrete with impregnation. However, I want the surface to be even smoother and to remove dirt. So I plan to polish it again. After that, reapplying impregnation makes sense.
Exposed concrete is already smooth. Really smooth. I’m not sure how you could make it smoother.
It’s also important to understand that regular formwork concrete, not executed as exposed concrete, will never achieve the finish quality of exposed concrete when ground. The mix and workmanship simply don’t allow for that.
rick201824 Dec 2019 10:50
The stairs and wall are explicitly exposed concrete quality. Our other walls are not, but are similar in style. The surface quality can be improved by grinding. The concrete was selected accordingly for this purpose.
Polishing achieves a high-gloss finish, which has less to do with the concrete quality. It then resembles polished natural stone. I only grind to a satin finish.
So even a seemingly smooth wall can be further smoothed. The tactile feel will be different, though. It’s a matter of personal preference what you want.
The advantage is that dirt and splashes are also removed immediately.
mini_g!
24 Dec 2019 10:57
rick2018 schrieb:
So, I polished it again. After that, reapplying a sealant makes sense.
In our current apartment, the interior wall to the neighbor is made of factory-produced precast concrete elements, filled with cast-in-place concrete. I would say it’s similar to your system.
The surface is perfectly smooth and doesn’t produce any sand. We simply left it as is and haven’t had any problems for 10 years.
I would be concerned about achieving a consistent finish, as sanding and sealing can quickly change the appearance completely.
But you can see the walls yourself and are best able to judge. I really appreciate that you’re getting personally involved and helping out. When you put in the work yourself, the result feels truly yours—whether it’s a huge house or a small cabin!
Best regards! mini
rick201824 Dec 2019 11:12
We also considered just leaving the walls as they are and sweeping them off.
Applying a sealant makes sense because it prevents liquids from being absorbed as much, or fingerprints from children...
It’s not absolutely necessary, though.
We want a slight gloss level, and the concrete texture will stand out more.
Sealing usually does not change the appearance as much (or at all) compared to varnishing. As mentioned, I will first test different products in less visible areas.
The photo is somewhat misleading because there is still sanding dust on the wall.
rick201824 Dec 2019 11:14
Of course, I want to do some things myself in my house. It doesn’t matter to me how big or small the project is or how expensive it is...
On top of that, grinding the concrete would have been disproportionately expensive. I’m not too proud to do that myself.
