Created on: 11 Sep 2018 07:32
rick2018
Now a bit about me:
Greetings from Swabia
Now a bit about me:
rick2018 schrieb:
In the living area, the concrete is impregnated and in the garage sealed with water glass.What product do you use for the impregnation? After extensive research, I’ve decided to use Keim products for our stairs. We clean with the concrete quick cleaner (although they were wrapped in wood during the construction period, it did get wet several times), then apply the Silangrund primer, and finally just the Fixativ from the Concretal glaze. We skip the glaze itself because we don’t want to change the color. I hope it will result in a finish that is as matte and invisible as possible...That sounds more like sealing?!
I will just lightly polish the steps (which are currently wrapped) to remove the dirt and then apply a protective impregnation.
I am not yet sure which product I will use for the walls and stairs. For the garage, I will use water glass (sealing).
I will test different impregnations in the utility rooms and then use the best one for the living areas as well.
rick2018 schrieb:
Sealing a garage with water glassTell me more, I’m not familiar with that yet.https://www.instagram.com/11antgmxde/
Our exposed concrete staircase was delivered as a precast element and remained covered for a long time. It withstood the construction phase well, but I would like to clean it again. My wife thinks it looks fine as it is. We’ll see.
The staircase was impregnated at the factory. It works quite well.
@11ant Water glass is a proven solution for sealing or preventing sand erosion. It is also used for basement and wall waterproofing, as well as for fire protection. Affordable, simple, and effective. There is no mechanical stress on the walls anyway. Potassium water glass is the optimal choice in terms of price and performance.
