Created on: 11 Sep 2018 07:32
rick2018
Now a bit about me:
Greetings from Swabia
Modern villa with flat roofs, terraces, glass surfaces, green surroundings – several views.
rick201822 Dec 2019 12:31
@Tina mit K
Grinding concrete is different from sanding plaster. Concrete is much harder.
For example, when leveling the floor with a concrete grinder, it produces a lot of dust.
Our walls are already quite even, so I can start right away with the sanding or polishing discs.
The material removal is minimal, but a very fine sanding dust is created. With good dust extraction (fine filter, etc.) it’s not a problem. Dust extraction doesn’t work as well on edges, but overall it’s not a big issue. The messiest part for me is cleaning and putting away the tools.
Wearing a mask is still advisable.
@Domski I use a system from Hilti (DGH 130). The material removal with the sanding/polishing discs is quite low.
As with any rotary machine, you have to move parallel to the wall. If you tilt it, you get (slight) marks.
But it’s not like plaster where you can easily get an edge with 1cm (0.4 inch) depth.
The goal is for the walls to be smooth. They don’t need to be perfectly flat.
guckuck2
22 Dec 2019 12:40
But the building material itself does not allow for that. (Exposed) concrete is a natural product. Perfection simply does not belong there.
rick201822 Dec 2019 12:54
In theory, it is possible. The question is what effort it would require. We share your view as well. It is a natural product, so it should not be 100% uniform—neither in surface nor in appearance.
Anolca*
22 Dec 2019 20:16
Awesome! What a project!
For me personally, that would be a total disaster, but it’s great to see something like this... I’m really curious to see how it will look when finished.
Wishing you continued success.
rick201822 Dec 2019 21:40
Why a major disaster? Too big? Rooms too large? Style?
Anolca*
22 Dec 2019 21:49
Honestly, all three apply, and it’s also an extreme use of resources for a home for two people.
My dream house, if space for storage and practical use weren’t a concern, would be more like a crooked, whimsical witch’s house.
But fortunately, tastes vary so much, and I like it when someone does their own thing.
