ᐅ Are there any DIY projects using IKEA Brimnes furniture that are especially worthwhile?
Created on: 23 Aug 2022 10:07
gutike
I’m planning to customize one of my IKEA Brimnes furniture pieces to make it more unique. I’m interested in DIY projects involving these pieces, especially those that are particularly worthwhile or truly feasible. Does anyone have experience or ideas on how to enhance Brimnes furniture in a practical and sustainable way? I’m especially curious about projects that add real value, not just aesthetically but also functionally. Are there any tips for reinforcing, adding to, or cleverly modifying them?
Thanks in advance for all the suggestions!
gutike
23 Aug 2022 15:05
Matthewt48 schrieb:
In my experience, it’s especially worthwhile to customize the drawer fronts – for example, by replacing the handles or inserting glass or acrylic panels.
That sounds very interesting, especially replacing the handles has been on my mind for a while. Do you know if the drill holes on Brimnes are standardized, or will I need to drill new ones every time? I want to avoid changing the structure too much to not compromise stability.
GLALEO schrieb:
I once turned a Brimnes chest of drawers into a DIY TV sideboard by adding castors underneath and repainting the surface.
How exactly did you go about that? Did you have any issues with stability on the castors? That would be an option for me too if it works out solidly.
Matthewt48
23 Aug 2022 15:37
Gutike, the drill holes are unfortunately not always 100% standardized at IKEA, especially with older models there can be differences. I would recommend comparing the existing holes with the size of the new handles and, if necessary, carefully marking new ones. Important: Always drill slowly and precisely to avoid damaging the wood.
For stability, it is better to reinforce the area around the drill holes on the front side with a small wooden strip or painted-on repair filler – this prevents wobbling or breaking.
Modifying the drill holes usually does not affect the load-bearing capacity of the furniture, as the main load is supported by the connections of the carcass parts. When replacing the handles, it is more about being gentle and applying little force to the front panel.
GLALEO
23 Aug 2022 16:05
gutike schrieb:
How exactly did you proceed? Did you have any issues with stability on wheels?
I used simple furniture casters with brakes, attached to the corners of the dresser. I carefully measured everything beforehand and screwed them into the reinforcements, not just the thin panels. Then I prepared the surface with sandpaper and painted it with chalk paint. The stability is excellent because the casters are firmly mounted and the dresser doesn’t wobble. Highly recommended!
sarlo
23 Aug 2022 16:47
I replaced the back panel of a Brimnes wardrobe with a plywood board, which not only improved stability but also reduced the wobbling when opening the doors. Additionally, I installed magnetic catches on the doors – this gives a high-quality and practical feel.
Furthermore, I fitted LED strips inside that automatically turn on when the doors are opened. This adds significant value, especially if you use the furniture for storing accessories or electronic equipment.
Such modifications are worthwhile both functionally and aesthetically.
Joshbe
24 Aug 2022 09:12
As a supplement: The Brimnes system is characterized by modular simplicity. For DIY projects, it is important to keep in mind that the panels are relatively thin, usually 15 mm (0.6 inches) particleboard. Reinforcements at heavily loaded points are therefore advisable.
It is recommended to replace the back panel of cabinets with solid wood. This makes the furniture more durable and ensures it remains stable under load.
When modifying items, such as adding casters or applying a new finish, it is important to transfer the load to the supporting components, not just the thin side panels. Adhesive and screw connections at the carcass edges help maintain stability.
I also recommend choosing high-quality hardware for handles or casters to ensure lasting assembly.
noken
24 Aug 2022 10:20
I think it’s great how many useful ideas you’ve all already shared. I’ve personally always been a bit hesitant to modify my Brimnes furniture because I thought the low price might come at the expense of stability.
It’s reassuring to know that reinforcing the back panels and replacing handles seem to be possible without major risks. It would be interesting to hear if anyone has also experimented with the surface, such as staining or creative painting, without compromising quality.
I really like sarlo’s LED idea; lighting like that can make a big difference, especially in small rooms.
