ᐅ Where can I find affordable replacement parts for Ikea Brimnes furniture?
Created on: 14 Apr 2022 08:27
LoamitHello everyone, I am specifically looking for affordable replacement parts for IKEA Brimnes furniture, as some screws and fittings on my dresser are damaged. I would prefer not to replace the entire piece of furniture and am wondering where to find such parts cheaply and reliably. Has anyone had experience with official or alternative sources for original or compatible replacement parts? I would appreciate any tips or specific suppliers you could recommend.
Basically, the first point of contact for replacement parts for IKEA furniture is always the IKEA customer service. There, you can often order specific small parts, such as screws, handles, or hinges. However, the prices are not always affordable, especially for small individual parts. As an alternative, I recommend:
- Secondary marketplaces like eBay or specialized spare parts shops
- Local hardware stores for generic screws or nuts (make sure to check the dimensions!)
- Online retailers that specifically sell replacement parts for IKEA furniture
It is important to pay attention to compatibility, as some components are model- or series-specific.
Hello Loamit,
I understand your situation well. Replacement parts for Brimnes furniture are usually available through IKEA, depending on whether they are still in stock, which often depends on the age of the piece. If IKEA no longer carries them, I have had good experiences with online marketplaces. With some luck, you can find suitable components there—even if they are not always original parts.
If only screws or small fittings are needed, it is worth identifying the exact dimensions and types to find similar items at specialty stores or hardware stores. Often, original parts are not necessarily more expensive than comparable quality products from accessory suppliers.
Maybe you could briefly describe which parts you are looking for? That way, it will be easier to provide more targeted help.
Thanks for the initial tips! It mainly concerns some connecting screws (from my research, probably Euro screws with a 15mm (0.6 inch) head), as well as two hinges on the drawers and a handle that is damaged. Ideally, as mentioned, it should be affordable but also of suitable quality to maintain the stability of the chest of drawers. Are there any special recommendations regarding product quality or interchangeability for such parts?
baAlejandr14 Apr 2022 11:27Loamit schrieb:
The main issue concerns some connecting screws (according to my research, probably Euro screws with a 15mm (0.6 inch) head), as well as two hinges on the drawers and one damaged handle.With Brimnes, it is important to pay attention to the specific IKEA screws, as they often have a unique length and thread type. Screws can sometimes be replaced with standard Euro screws if the length and head size match.
For hinges, it is recommended to get the originals, as they are often designed to work with the drawer slides. Handles usually vary depending on the model; here, it is worth ordering an original or a well-fitting replacement that you know matches the hole spacing exactly.
Tip: For damaged handles, you can often find affordable suitable alternatives at hardware stores or furniture accessory shops with some research. Pay close attention to the hole spacing.
RonJarrett14 Apr 2022 12:03In addition to the sources already mentioned, I recommend replacing products only with parts that match the original quality. Using cheaper generic screws or hinges carries the risk of faster wear or poor fit, which can affect functionality.
For screws:
- Action: Determine the exact length, thread type, and head shape
- Recommendation: Visit a supplier that allows filtering screws by precise technical specifications.
For handles and hinges:
- Original parts through the IKEA service or authorized spare parts dealers
When it comes to replacement parts that directly impact function and safety, quality should take priority.
For screws:
