ᐅ How durable are IKEA BRIMNES furniture pieces with frequent use?
Created on: 17 Dec 2020 08:13
Hauka
I recently purchased some furniture from the IKEA Brimnes series, including cabinets and dressers, and I am increasingly concerned about how sturdy these pieces are with frequent use—especially regarding the hinges, drawer load capacity, and the durability of the joints. It is important for me to know whether this furniture holds up well after several years of intensive use or if there are typical weak points to consider before buying. Perhaps there are experienced users or assembly experts here who can provide informed insights on this.
Since BRIMNES is relatively affordable, I sometimes worry that its stability might not be as good as that of more expensive collections. I would appreciate any serious evaluations, including suggestions on how to potentially improve its longevity. Thanks in advance!
Ramon4
18 Dec 2020 09:37
Hello Hauka,
In response to your question, I’d like to share some practical tips I’ve gathered over the years with IKEA furniture, including the Brimnes series:
- Always follow the assembly instructions completely and step by step, especially when carefully screwing in the screws.
- Never overtighten screws to avoid material breakage, but also don’t leave them too loose.
- After about 4-6 weeks of use, check all screws and connections and tighten them slightly if needed.
- If certain screw holes have become stripped, you can fill them with wood glue and small wood shavings, then reinsert the screw.
- Especially for drawers: regularly clean the runners and apply a light lubricant to reduce mechanical stress.
These small maintenance steps really help keep the furniture stable and extend its lifespan. A little care goes a long way with affordable furniture.
fiman
18 Dec 2020 10:04
A brief note about drawers: Never store too much weight in them. Otherwise, the slides will wear out quickly, and the fronts may warp.
Elias
18 Dec 2020 14:31
I understand the concern about potential defects with BRIMNES. I felt the same way when I bought several pieces of this furniture for my office two years ago.
At first, I was nervous because I had often heard that IKEA furniture might wear out quickly. However, with regular tightening of screws and careful handling, the issues have been manageable.
I also want to encourage you: although the furniture shows signs of use, this actually gives each piece some character. Considering that it isn’t solid wood, the problems often seem minor. And yes, there are sometimes small frustrating moments, but overall the benefits outweigh them.
As with everything, it's important to take care of things and avoid overloading them. That’s how I have come to really like my BRIMNES.
maunau70
18 Dec 2020 15:16
I had BRIMNES dressers in the common area, used frequently. The load capacity is fine, no defects so far. However, always check the screws regularly.
SUDAN
19 Dec 2020 08:06
Hauka schrieb:
Are there, for example, screws or joints that should be monitored closely?
Yes, especially the screws that hold the drawer slides are very important. If they become loose, the drawers can quickly become unstable or rattle.
The corner joints on the carcasses are also critical because they affect the overall stability. If you want, you can reinforce them with small metal brackets without altering the original structure.
Important: Never overtighten screws, as this can cause the material to split.
