ᐅ How durable are IKEA Brimnes furniture pieces for frequent moving?
Created on: 12 Apr 2021 09:04
Pin65
Hello everyone, I am planning to move several times in the near future and am wondering if the IKEA Brimnes furniture is sturdy enough for frequent moves. Since the furniture is often made from particleboard and relatively simple joints, I’m curious how well it holds up to repeated assembly and disassembly. Does anyone have experience with how durable Brimnes dressers or beds are when taken apart, transported, and rebuilt multiple times? I would appreciate if you could share your opinions or tips, especially if there are any weak points that tend to wear out quickly when the furniture is moved often.
Pin65
12 Apr 2021 12:03
Thank you for your responses so far!
KUDAISY schrieb:
Avoid over-torquing the screws, as this often damages the material at the joints.
Could you please explain in more detail how to best avoid this without the furniture parts being too loose? Are there any tips for tightening or perhaps specific tools that help?
KUDAISY
12 Apr 2021 12:47
Gladly!
The most important thing is to get a feel for the resistance when tightening: you should use the screwdriver or cordless drill in a way that lets you sense when the material is reaching its limit. A cordless drill with adjustable torque is ideal, as it allows you to limit the force applied.
If you only have manual tools, first tighten the screw by hand, then finish tightening without applying too much force. The screw should fit securely, but it shouldn’t be forced into the material.
For wooden panels, it’s also helpful to gently pre-drill if possible to prevent the material from splitting.
Summary:
- Limit the torque
- Avoid overtightening screws
- Pre-drill where possible
This significantly extends the durability of the joints, especially with frequent moves.
Pin65
12 Apr 2021 13:18
Traman4 schrieb:
Brimnes can handle a few moves if you’re careful. After that, the screw holes often become worn out, and the furniture gets wobbly.
How many moves would that be approximately under normal conditions? And would you recommend buying replacement parts from IKEA, such as dowels or special screws, to secure the furniture again?
V
volker0
12 Apr 2021 13:42
In my case, there were about three moves over five years. It is worth buying replacement parts; IKEA usually has the appropriate screws and fittings.
LAURE-TA
12 Apr 2021 14:10
Hello everyone, I would like to add a practical tip:
1. For furniture like Brimnes, special attention should be paid to the corner joints – these can become loose quickly with frequent moves.
2. For a more stable assembly after several moves, you can apply wood glue into the worn screw holes and press in small wood chips – this fills the voids created.
3. Alternatively, special furniture repair kits available at hardware stores can help renew enlarged holes.
Conclusion: With a bit of DIY effort, Brimnes furniture can be kept stable even after multiple moves.
Guyju
12 Apr 2021 14:38
I would like to add something about the load:
If the furniture is mainly used for light storage or as a shelf, the stress from moving is less critical. However, if the bed or wardrobe is frequently loaded, cracks and fraying may appear on the edges. During transport, it is best to protect the edges with blankets and avoid strong bending.
Here is a brief guide for safe disassembly and reassembly:
- Lay the furniture horizontally on a soft surface
- Carefully loosen screws and fittings
- Hold the piece close to prevent it from falling uncontrollably
- When reassembling, loosely fit each part first, then tighten firmly
This helps minimize damage.
