I am currently considering purchasing some furniture from the Ikea Brimnes series, specifically beds, dressers, and wardrobes. Since I value durable and sturdy furnishings in my apartment, I am wondering how stable these Brimnes pieces actually are with frequent use.
Specifically, I’m interested in:
- How well do bed frames and slatted bed bases hold up to daily stress such as getting in and out of bed and heavy weight?
- How durable are the drawers and hinges with regular use, especially in dressers and wardrobes?
- Are there common issues with warping, wobbling, or wear in the wood-based materials and joints?
If anyone has experience, I would appreciate learning more about the everyday durability. Concrete tips for maintenance or improving stability are also welcome.
Thanks in advance for your feedback!
The Ikea Brimnes furniture is generally designed for normal residential use, but it should not be subjected to excessive stress, such as enthusiastic jumping on the bed or frequent heavy loading and unloading of the drawers with overly heavy items.
Details:
- The bed frames are made with particleboard and central support beams, which provide sufficient stability for average loads. They are sturdy for daily use, provided the slatted bed base is properly adjusted.
- The drawers run on metal rails that are durable enough for frequent use, although overloading will shorten their lifespan.
- Weaknesses often appear at the joints of the wood-based panels, especially if the furniture is stored in damp conditions or assembled incorrectly.
In general, I recommend following the assembly instructions carefully and avoiding placing the furniture in areas with high humidity.
Details:
I can only agree with Lucien here, but I’d say this: For the price, Brimnes really offers surprising stability! 😊 Of course, it’s not solid wood or a high-end piece of furniture, but the drawer mechanism and design are quite clever.
It also helps not to stuff the chest of drawers immediately with 50 kilograms (110 pounds) of books – it needs some room to breathe. 😉
Oh, and regarding the bed: I reinforced my slatted frame a bit – it makes the whole setup a bit sturdier in case a friend stays over spontaneously!
Nathanaelk3 May 2024 15:29I would like to add some technical details regarding the stability of the Brimnes series:
The carcass panels are mostly made of veneered particleboard with thin MDF layers, which generally allows for a good distribution of weight but is less sturdy than solid wood. The fasteners are usually dowels plus metal screws, providing a fairly solid structure; however, over time some looseness can develop if the screws are not regularly tightened.
The bed frames include a central slat support that is suitable for average people with standard mattress weights. However, anyone weighing significantly over 100 kg (220 lbs) or using the bed very frequently should consider adding a slatted base support or additional braces.
The drawers sometimes experience wear on the runners when overloaded or opened and closed too quickly. Under normal use, the lifespan of this mechanism is at least 5 to 7 years.
I would also be interested to know how often the furniture is used daily and the level of stress it is subjected to – whether it is a single-person household, a family with children, or shared accommodation. This can affect the assessment.
Nathanaelk schrieb:
I am also curious about how often the furniture is used daily and how heavy the usage is – more like a single household, a family with children, or shared living? That can change the assessment.Good question, thanks!
I live alone and use the bed and dressers daily—at least the bed every day, and the dressers/cabinets several times a day. In terms of weight, I’m average at around 80 kg (176 lbs), so nothing excessive. Regarding wear and tear: the furniture needs to be sturdy enough to last well beyond a few years because I don’t want to keep upgrading or repairing.
It is also important to me that the drawers and doors don’t start to wobble or stick, which I’ve experienced with cheaper furniture.
