ᐅ What repair tips are available for IKEA BRIMNES furniture?
Created on: 16 Dec 2024 09:17
NAUPIN
NAUPIN
16 Dec 2024 09:17
Hello everyone, I own several IKEA Brimnes furniture pieces—mainly cabinets and dressers—and I have noticed that some joints start to become loose or wobbly over time. My question is: What repair tips or proven methods are there specifically for Brimnes to stabilize or readjust the furniture? I am particularly interested in approaches that require minimal extra materials, as I do not want to order complete replacement parts. Are there common weak points to watch out for or standard screws/connections that should generally be checked more often? Any advice is welcome—tips for surface care are also appreciated if repair and maintenance go hand in hand.
Paunon
16 Dec 2024 09:34
As a rule, I always recommend first tightening all screws and anchors, as usually only those loosen over time. This often significantly helps with BRIMNES. If there are edges coming loose, wood glue can help, but use it sparingly.
Filippo
16 Dec 2024 10:27
I want to go into a bit more detail because BRIMNES can actually have several typical weak points. Often, the issue lies with the connecting hardware, especially the cam lock screws and connector screws used on the back panels. My advice: systematically loosen the screws and fittings, lightly treat them with a lubricant (not oil, graphite powder is better), and then tighten them again. This helps prevent the threads in the wood from expanding or jamming. If the furniture wobbles, you should check whether the back panel sits flush; sometimes placing a thin piece of cardboard behind the back panel is enough to improve the fit. Which specific areas are wobbly for you? Are they drawers, doors, or the entire piece? That could help to respond more precisely.
NAUPIN
16 Dec 2024 11:05
Filippo schrieb:
Which specific parts are loose for you? Are they drawers, doors, or entire pieces of furniture? That might help address the issue more precisely.
Thank you for asking! Mainly with my BRIMNES dressers, the side panels are no longer tightly connected to the back panels, and occasionally the legs feel a bit unstable when I move the furniture—it also creaks then. The doors haven’t caused any problems so far, but some of the drawers run a bit roughly. I suspect that the stressed joints in the lower area are the most affected. I will try a lubricant; do you think graphite powder would provide the best results?
blapau
16 Dec 2024 11:48
Graphite powder is an option for wood joints, but for furniture made from pressed wood, I would recommend using a dry lubricant with PTFE instead. This spreads more evenly without causing the wood fibers to stick together. For the stability of the legs, I suggest regularly checking the screws there. If the original screws are too short, you can use slightly longer ones from a hardware store, which greatly improves stability. For the back panels, attaching additional angle brackets from the inside can also help, although this is a minimally invasive modification.
Paunon
16 Dec 2024 12:15
blapau schrieb:
If the original screws are too short, you can use slightly longer ones from the hardware store, which greatly improves stability.
That's a good point. I have done the same with the screws, and it noticeably increases the holding strength.
