Created on: 31 Jan 2020 13:29
Shiny86
Slope yes
Site coverage ratio?
Floor area ratio?
Boundary development?
Number of parking spaces 2
Number of floors 2
Maximum heights/limits
Additional requirements?
Clients’ Requirements
Number of occupants 4
Open kitchen, kitchen island
Number of parking spaces 8-10
Garage
Who designed it?
-Architect
What don’t you like? Why?
Good: large living area
Slope yes
Floor area ratio?
Number of floors 2
Garage
Who designed it?
-Architect
- Where could it still be optimized? Would you recommend different window dimensions or sill heights?
- What do you think is poor or what would you do differently?
- A partition wall will be added in the walk-in closet. That would theoretically allow watching TV from the bed. I am considering a lightweight wall. I plan to place a 211cm (83 inches) Pax combination wardrobe in the closet. The closet is planned with a raw width of 218cm (86 inches). Do you think 218cm is enough for the Pax once the walls are plastered, or how wide should the rough dimensions preferably be?
- Is the hallway on the ground floor too narrow?
- Would you raise the ground level? The house would be 40cm (16 inches) below street level. If I build a terrace into the garden, it would be about 1m (3 ft) difference. You could raise only the house level, resulting in approximately 1.6m (5 ft) difference between terrace and garden. I don’t know anyone living below street level. Raising the garden would probably not be allowed without permits, and affected neighbors likely wouldn’t agree. On the sides of the house adjacent to neighbors, raising is permitted only up to certain limits. I am overwhelmed with the decision.
- Do you have any ideas for arranging the sofa differently and placing the TV sensibly? My husband doesn’t want the sofa back facing a window. I still need to get used to placing the sofa in the middle of the room.
- Is the kitchen size sufficient for a nice kitchen with an island?
Alessandro14 Apr 2020 08:20It’s commendable that you’re thinking about every little detail, but these are things for the main contractor to handle! Just tell them that you need to fit a 220 cm (87 inch) wardrobe there, and they will take care of the rest.
The main contractor also knows about the windows. You don’t want too much wall between the ceiling and the window? Let the main contractor know! I didn’t take as long for the entire house planning as you did just for the windows.
Shiny86 schrieb:
I’m planning to use a 2.20m (7 ft 3 in) Platsa wardrobe from Ikea for the closet.
Do you think that if I design the niche with a length of 2.25m (7 ft 5 in), it will fit?The plaster will add about 1.5–2cm (0.6–0.8 inches) on each side. But keep in mind, you’ll also have baseboards along the floor, which take up about 1–2cm (0.4–0.8 inches) of space.
Sabine
Alessandro14 Apr 2020 09:00A baseboard in a recess where a built-in wardrobe is to be installed???
Alessandro schrieb:
a baseboard in a niche where a built-in wardrobe is supposed to be installed??? It’s supposed to be a Platsa wardrobe from Ikea, which is not a built-in wardrobe and definitely not meant to last forever. We also have the same one in our hallway.
Sabine
Alessandro14 Apr 2020 09:10What if you place a cabinet in a niche that has been specifically designed for it, and then install 2cm (about 0.8 inches) baseboards on both sides to act as dust collectors and to cover the gaps?
Baseboards are quick to install and can always be added later if you decide you don’t want a cabinet there anymore.
