ᐅ Floor Plan Optimization for Urban Villa + Considerations for Land Elevation
Created on: 31 Jan 2020 13:29
Shiny86
Plot size 492 sqm (5293 sq ft)
Slope yes
Site coverage ratio?
Floor area ratio?
Building envelope, building line, and boundary?
Boundary development?
Number of parking spaces 2
Number of floors 2
Roof type Pyramid roof, 25 degrees
Architectural style Modern urban villa
Orientation Main entrance facing north
Maximum heights/limits
Additional requirements?
Clients’ Requirements
Modern urban villa with pyramid roof, 25 degrees
Basement, floors 2 full floors without basement
Number of occupants 4
Open kitchen, kitchen island
Number of parking spaces 8-10
Garage
Who designed it?
-Architect
Large living area, master bathroom
What don’t you like? Why?
Utility room quite small and master bedroom small, children’s room somewhat too large
The architect implemented the corresponding wishes
What do you think is especially good or bad about it?
Good: large living area
I am uncertain about the half-height window sizes and the swing direction of the doors
  • Where could it still be optimized? Would you recommend different window dimensions or sill heights?
  • What do you think is poor or what would you do differently?
  • A partition wall will be added in the walk-in closet. That would theoretically allow watching TV from the bed. I am considering a lightweight wall. I plan to place a 211cm (83 inches) Pax combination wardrobe in the closet. The closet is planned with a raw width of 218cm (86 inches). Do you think 218cm is enough for the Pax once the walls are plastered, or how wide should the rough dimensions preferably be?
  • Is the hallway on the ground floor too narrow?
  • Would you raise the ground level? The house would be 40cm (16 inches) below street level. If I build a terrace into the garden, it would be about 1m (3 ft) difference. You could raise only the house level, resulting in approximately 1.6m (5 ft) difference between terrace and garden. I don’t know anyone living below street level. Raising the garden would probably not be allowed without permits, and affected neighbors likely wouldn’t agree. On the sides of the house adjacent to neighbors, raising is permitted only up to certain limits. I am overwhelmed with the decision.
  • Do you have any ideas for arranging the sofa differently and placing the TV sensibly? My husband doesn’t want the sofa back facing a window. I still need to get used to placing the sofa in the middle of the room.
  • Is the kitchen size sufficient for a nice kitchen with an island?
What do you think about the floor plans?
Floor plan of a single-family house: living/dining area, kitchen, hallway, storage room, cloakroom, WC.
Floor plan of a family home: CHILD 1, CHILD 2, PARENTS, WALK-IN CLOSET, BATHROOM, SHOWER/BATHROOM, HALLWAY.
Architectural drawing: two-story residential house with garage; southwest and northeast views.
Two facade views of a house: northwest and southeast with roof, windows, terrace, and garage.
Curly
11 Apr 2020 14:56
Shiny86 schrieb:
But now I have to determine the sizes.
With a ceiling height of 2.55m (8 ft 4 in), does that mean a maximum height of 1.3m (4 ft 3 in) for half-height walls, since you consider a sill height of 90cm (35 inches) plus 3cm (1 inch) window ledge ideal?
So would you choose 1.01/1.30 or 2.01/1.30?
I mean a finished sill height of 90cm (35 inches), including the window ledges. You should upload your plans so we can discuss the window widths.
Sabine
Shiny86
11 Apr 2020 17:13
If the floor plan shows a parapet height of 87cm (34 inches), does that mean 87cm (34 inches) measured from the finished floor surface, and then you always add 3cm (1 inch) for the window sill?
What dimensions are common for windows?
Are 1.01/1.30 meters (3.3/4.3 feet) and 2.01/1.30 meters (6.6/4.3 feet) standard sizes?
Shiny86
11 Apr 2020 17:27
opalau schrieb:
Doors 2.13 m (7 ft)
Finished window opening 2.27 m (7 ft 5 in)
Sill height 0.99 m (3 ft 3 in)
What dimensions do you have for your windows, for example?
Do you have roller shutter boxes?
Shiny86
11 Apr 2020 17:45
@Curly
This is the room layout, but scaled down to 10.6 x 10.6 m (35 x 35 ft).
The children’s rooms will have additional windows facing east and west. What window dimensions would you choose?
Attic floor plan: two CHILDREN’s rooms, PARENTS’ bedroom, walk-in closet, hallway, bathroom, shower/bath.
opalau11 Apr 2020 17:49
Shiny86 schrieb:
What are your window dimensions, for example?
We have four different widths: 76cm (30 inches) for example for the guest bathroom, 101cm (40 inches), 113.5cm (45 inches) for patio doors, and 202cm (80 inches) for double patio doors. The two mentioned heights are 126cm (50 inches) and 227cm (89 inches).
As mentioned here before, roller shutter boxes were installed between the window and the ceiling. In our case, they were about 25cm (10 inches).
Shiny86
11 Apr 2020 18:06
opalau schrieb:
We have four different widths: 76cm (30 inches) for example for guest toilets, 101cm (40 inches), 113.5cm (45 inches) for patio doors, and 202cm (80 inches) for double patio doors. And the two mentioned heights of 126cm (50 inches) and 227cm (89 inches).
And the roller shutter boxes, as mentioned here before, were placed between the window and the ceiling. For us, that was about 25cm (10 inches).
Ah, okay. That helps me. It’s very similar to what we are planning. Would you plan it the same way again?
