ᐅ Professional and visually appealing installation of Ikea Metod baseboards
Created on: 23 Aug 2024 09:12
ISLALAU
ISLALAU
23 Aug 2024 09:12
Hello everyone, I am currently assembling my Ikea Metod base kitchen cabinets and looking for practical advice on professionally and aesthetically installing the kickboards. Specifically, I am interested in how to mount the kickboards so that they are stable but also achieve a clean, uniform appearance — especially when dealing with different floor coverings and uneven wall dimensions. Are there any recommended tools, installation steps, or tips to make the kickboards look seamless? Additionally, I would like to know whether it’s better to attach the kickboard directly to the cabinets or to the wall, and how to create neat transitions, for example at corners or door openings. I appreciate any professional recommendations!
blapau
23 Aug 2024 11:27
Basically, I recommend attaching the baseboards directly to the cabinets rather than to the wall. This keeps the system flexible and allows for better compensation of any unevenness in the floor. For a clean finish at corners, the baseboards should be cut precisely at a miter, preferably using a miter box or a precise jigsaw. Another important point: be sure to check the alignment of the substructure, meaning the cabinets, before installing the baseboard to ensure everything is flush. Also, use appropriate mounting screws and, if possible, small concealed clips to avoid affecting the appearance. A laser measuring device can help accurately check distances and levelness.
ju_ren
23 Aug 2024 13:03
Attach the baseboards to the cabinets, make miter cuts at the corners, seal the lower edge with sealant, done.
Nabla64
23 Aug 2024 15:42
I would like to add that it is worth thoroughly checking the floor before installing the baseboards. Small uneven spots can be leveled with leveling compounds or thin foam behind the board to ensure it sits flush. For corners, I recommend cutting the baseboards with a precise angle measuring tool and assembling them dry first to check the fit. It is also important to attach the baseboards so that they have strong joints and fastenings in high-traffic areas, such as near door openings. Finally, a tip: a matte white silicone sealant along the joints can visually hide small gaps without damaging the surface.
Joshbe
23 Aug 2024 16:37
The manufacturer’s instructions for Ikea Metod recommend attaching the baseboards directly to the cabinets using the included clips. This ensures the necessary stability and makes future disassembly easier. For a visually seamless surface, it is important to cut the baseboards at the corners with precise miters and to check the measurements with a caliper or protractor before final installation. Uneven floors can affect the fit, so floor preparation may be advisable beforehand. Painted baseboards should be carefully sanded with fine sandpaper to prevent paint chipping during cutting.
ISLALAU
24 Aug 2024 08:59
Thanks for the tips so far! One question: Do you see any issues when installing on uneven floors if you only attach to the cabinets? Since the floor varies by up to 1.5 cm (0.6 inches) in some areas, the baseboard might not lie flat all the way around. What would be the best approach in this case? Should the baseboards be fixed to the wall, or would it make sense to use foam strips? How do you handle this in practice?
