ᐅ Which wood edge sealants are suitable for furniture made from Ikea Besta?
Created on: 7 May 2024 08:17
WolframmanW
Wolframman7 May 2024 08:17Good morning everyone,
I am planning to improve my Ikea Besta shelving unit by adding custom wooden edging, specifically to enhance the appearance of the edges and better protect them against moisture and mechanical wear. The question I have is: Which wood edge sealants work well for Ikea Besta furniture, especially considering the combination of the typical melamine substrate of the Besta and the application of oiled or varnished wooden strips?
I am particularly interested in sealants that adhere well to melamine edges, are neither too glossy nor too brittle, and provide a durable surface. Is it generally better to use oil, varnish, or wax in this case? Also, what is the recommended surface preparation before sealing?
I look forward to factual experiences or recommendations from you professionals and hobby carpenters!
Basically, when working with Ikea Besta furniture that has melamine-coated surfaces, it is important to note that sealants have limited adhesion on melamine foil.
- Oils provide a natural look and penetrate wood, but are hardly effective on melamine since melamine is non-porous.
- Waxes usually improve the feel but do not offer lasting protection and can remain slippery on melamine.
- Paints, especially water-based acrylic paints, form a film and adhere comparatively well if the edge is lightly sanded and cleaned from grease.
Therefore, it is recommended to seal the wooden strips separately—before attaching them to the Besta—with matte or satin acrylic paint to ensure surface durability. For sealing directly on melamine, paint is the best choice, even though the adhesion is purely mechanical.
Be cautious with oil applied directly on melamine—it can bead up over large areas or fail to dry properly.
usbla schrieb:
For sealing directly on melamine, paint is the best choice, even if it only provides mechanical adhesion.That’s pretty accurate. To apply the sealant optimally, you should first gently roughen the edge with fine sandpaper (grit 220 or finer). This slightly roughens the smooth, glossy melamine surface, which significantly improves adhesion for the sealant. After that, I recommend degreasing the surface with alcohol or a suitable cleaner to ensure no oily residues interfere with bonding.
Personally, I always treat wooden trim pieces that I attach to Besta with a high-quality, low-viscosity acrylic paint, applying at least two coats to achieve a protective, flexible, and matte finish.
Oils are often used on wood surfaces, but with IKEA melamine edges, they don’t work well and don’t absorb properly. Therefore, it’s better to use pre-sealed wood rather than sealing after installation.
Wax can be applied as an additional finish on top if a matte look and velvety feel are desired but it does not replace durable protection.
What type of wood edge trim are you planning? Veneered strips, solid wood, or even HDF?
Wolframman8 May 2024 07:45Surela schrieb:
What type of wood edge trim are you planning? Veneered strips, solid wood, or HDF?Thanks first of all for the quick and detailed reply! I am planning solid wood strips (beech) that I want to glue onto the visible edge of the Besta. This is to create a warmer and more refined look.
It is also important to me that the sealant is durable and resistant to fingerprints and occasional moisture, as the piece of furniture is in the living room and handled frequently. The finish should be matte and not glossy—more of a natural wood appearance.
I will treat the strips before attaching them. Are there any specific considerations when working with beech? Would it be better to use wax-based treatment or to lacquer it?
Also, what are the general experiences regarding hardness and scratch resistance of acrylic paints on beech? Are there products that are particularly recommended for this?
Wolframman schrieb:
Are there any special considerations when working with beech? Is it better to use wax-based products or paint?Beech is a hard, relatively dense wood that responds well to oils and waxes. However, I would be cautious about using only wax or oil on heavily used furniture edges, as these treatments only protect the surface and do not prevent deeper mechanical damage.
The advantage of paint lies in its hard, durable protective layer, which reliably repels moisture and significantly reduces abrasion.
Several thin layers of acrylic paint (or polyurethane) bond well with the wood surface, especially if it has been lightly sanded and cleaned. Acrylic paints with a matte or satin finish are ideal because they don’t produce a glossy look but still offer good durability.
Wax provides a warm and natural feel but should always be used as a supplementary protection after painting, never on its own on heavily stressed furniture edges.
Additionally, I recommend sanding the beech wood thoroughly (preferably starting with 180-grit, then progressing to 220-grit sandpaper) and removing all dust carefully. Using an acrylic primer might be beneficial if available, particularly if the wood tends to absorb moisture slightly and a very even surface is desired.
My conclusion: For a long-lasting, resistant sealing of beech wood edges on Ikea Besta units, a matte to satin acrylic paint is the best choice, ideally combined with wax on top for feel and appearance.
Filippo schrieb:
My conclusion: For a durable, resilient wood edge sealing on beech at the Ikea Besta, a matte to satin acrylic lacquer is the first choice, preferably combined with wax as a surface treatment for the feel.Interesting perspective. I just want to point out that many acrylic lacquers can actually be sensitive to scratches and wear, especially when applied in thin layers.
- Are there any experience reports on particularly durable acrylic lacquers?
- Could a matte polyurethane lacquer be a better alternative?
Do lacquers become brittle or yellow over time with normal household use?
I often see a preference for natural finishes, but one should also be pragmatic regarding daily use: finger taps, bumps, cleaning agents.
By the way, I agree that a wax finish alone is unsuitable for heavily used edges.
