ᐅ IKEA BESTA – How can I repair damage to melamine surfaces myself?
Created on: 18 Dec 2023 09:17
mejabar
mejabar
18 Dec 2023 09:17
Hello everyone, I have an Ikea Besta sideboard with a melamine coating, and unfortunately a small corner has been damaged. The coating has a noticeable chip or scratch, and I would like tips on how to repair this damage myself without having to re-laminate or repaint the entire piece. Are there proven methods or materials to fix melamine surfaces without professional equipment? I am looking for durable solutions that are visually appealing and make the damage as invisible as possible. Thank you in advance!
nolan
18 Dec 2023 09:45
Hi, for small damages, a special repair pen for melamine can help. You can find these at DIY stores. Otherwise, clear cyanoacrylate gel (super glue) can also work, which you can then sand and polish.
Filippo
18 Dec 2023 10:33
Good morning,
to repair damage to melamine surfaces like those on Ikea BESTA units, I would recommend a systematic approach:
- First, clean the damaged area thoroughly to remove dust and grease.
- If the coating has chipped off, carefully remove any loose parts without damaging the particleboard underneath.
- For small chips, repair kits for plastic or melamine surfaces are suitable; these often include a putty knife, sanding pads, and filler material.
- The filler (usually acrylic or epoxy-based) can be applied with a small spatula and must fully cure.
- After drying, smooth the area with fine sandpaper (400–600 grit) and then polish it to blend the surface with the surrounding melamine.
I’m interested to know: How large is the damaged area exactly, and is it a surface that is walked on or more of an edge? This can influence the choice of repair method.
Be sure not to apply the filler too thickly, as this could make the repair noticeable or cause the door to stick when closing.
LEEJU
18 Dec 2023 11:02
Furniture polish or special repair wax sticks often help with scratches. For larger damages, it is best to fill them with white wood filler or acrylic. After drying, lightly sand the area, and you're done.
Davidleo
18 Dec 2023 12:35
Hey! I had exactly the same problem with my BESTA. I got a repair kit from the hardware store back then, which was perfect for small damages! Just apply, let it dry, and it’s almost invisible! Really great, give it a try, it’s definitely worth it! 😊
klo61
18 Dec 2023 14:15
I understand how frustrating damage to melamine surfaces can be, especially on frequently used furniture like the BESTA.
In my experience, with a bit of care, good results are achievable. It is important to choose repair materials that match the color well – small tests on hidden areas often help.
An alternative to filler putty is wax sticks, which come in many colors and are particularly suitable for scratches. For chipped areas, acrylic filler is usually more appropriate. After it has dried, it is advisable to refine the surface with very fine sandpaper and, if necessary, some polishing compound to better replicate the typical smoothness of melamine.
I would also like to know how large the damaged area is and whether it is subject to heavy use?
